So I have installed the AutoCAD connector 2.5.1 and it is showing nothing on my AutoCAD Add-ins tab.
In the Speckle Manager app, it shows that the connector is installed.
Please can you help.
Thanks.
Thanks.
Hi @hpl and welcome to the forum!
Unfortunately, AutoCAD LT does not support plugins, you would need a full AutoCAD version.
Hi @Alireza_Alipour welcome to the forum!
Can you please confirm what version of Speckle for AutoCAD you have installed?
Does Speckle work/show up correctly in any other Software that we support?
Hi, thanks …
version of Speckle is 2.10.2
no, i need to work with autocad only …
That was the original solution - @Alireza_Alipour reported this error for full AutoCad and resurrected the thread.
If it is a full version, please check again assembly in computer, some time company block dll and not allow addin will be load
my autocad is part of civil 3d package, then when i install the civil 3d speckle, problem solved …
thanks for support … ![]()
Thank you @Alireza_Alipour that’s super helpful information to add to our troubleshooting list. ![]()
I am having the same issue, with AutoCAD 2021 FULL
Hi, @Professor_Germano let’s try and improve your first Speckle experience.
Can you specify the version of the Manager you are using?
What version of the AutoCAD Connector have you tried to install?
Are you installing for All Users or just yourself?
Are you within a corporate firewall or VPN?
Or give this a try:
In AutoCAD (or Civil3D), run the NETLOAD command.
Navigate to: C:\Users<USER>\AppData\Roaming\Autodesk\ApplicationPlugins\Speckle2AutoCAD (or Civil3D) and select the SpeckleConnectorAutoCAD.dll (or Civil)
This should prompt an approve dialog to always allow speckle. Accept that, then run Speckle command. You should be able to access the connector then.
Hi everybody,
sorry for the late reply, it has been busy on my side lately:
WOW, that made it!! Thanks, now I finally can try Speckle!
