Archicad - Doors and Windows not sent
I would also like to add that using the latest version of Speckle for Archicad> Speckle> Rhino, I noticed that windows and doors are not exported or transferred into Speckle. I was just wondering if this issue is under progress for getting solved or any idea for the possible solution.
Kind Regards
Niloofar
Hey Niloofar,
When you select walls in Archicad, hosted elements such as doors and windows do not get selected. This is not an issue with our software, but rather a limitation of Archicad. You will need to specifically select those elements if you want them to be included in the selection.
6 posts were split to a new topic: Archicad Windows missing in Grasshopper
