Hello everyone,
I am new to Speckle and looking forward to use it.
Are there any plans to create ArchiCAD connectors? It would be great as it would open up workflows between Revit - ArchiCAD project teams and workflows between ArchiCAD - Rhino - Grasshopper.
Currently, it is not on our roadmap to develop an Archicad Connector, but it’s something we’ll gradually get to at some point, though I’m afraid I can’t give you an ETA at the moment.
None of us are Archicad users and, as far as I know, we don’t have experience with their SDK either, so it may take a while. We’d be happy to support any community efforts on making this happen though
We most definitely agree and have added ArchiCAD and SketchUp to our road map, currently, the only blocker from our side is the lack of experience/skills developing for these software, but hopefully we’ll get someone on board that can help, or others (Graphisoft included) to contribute!
I’ve just pinged one of my connections!
Would definitely appreciate an intro to someone else over there who could help with this , you can use: matteo at speckle.systems
Quick update on this, we’ve had some preliminary, but very productive meetings with Graphisoft and will soon start to explore an integration whatch this space!
Hi @gergo and @teocomi,
This is very exciting! If you need any help from advanced ArchiCAD user for testing etc. let me know. We would be very happy to help! We are looking very much forward to this connector, since ArchiCAD is our primary 3D modelling tool in Norway and still somehow disconnected from our parametric workflows in RH / GH.
Hi @gergo, any advances on how are you planning to integrate the connector with ArchiCAD?
A dedicated set of GH components to perform CRUD operations on archicad elements would be great. I would be happy to help on this task (I have experience on GH component development)
Nowadays, the connection that Graphisoft has developed for Grasshopper is lacking important features as Delete/Update existing elements in the archicad database ( only Read/Create) so it would be great if this new speckle connector gives us ArchiCAD users the possibility to edit (even delete) existing elements remotely. An obvious use case would be to embed external data to existing ArchiCAD elements as “properties”.
thanks for the input, we certainly appreciate these real world usecase needs.
The ArchiCAD connector is planned to be very similar to all the other Speckle Connectors, so if you have used the Revit Connector for example, you should expect something similar (on first release we ofcourse cannot provide full element support parity). So we will support both sending and receiving to and from AC.
In that sense the connector wont provide a CRUD api to call from GH, but receiving a new commit, where an element has been modified in GH per say, would result in an updated element in AC.
Stay tuned, we might have something soon, and we’d love to have you test things out and discuss how it would fit your needs.
Thanks, this is great since “updating”, in my opinion, is the priority, as element “creation” ( I mean ONLY GDL based elements i.e Walls, Slabs, Windows, etc…) is already covered by Graphisoft´s GH connection,
Certainly, not all element “creation” are covered by GH Connection, other fundamental entities as Composites, profiles, Attributes, Views, Drawings… have been neglected by Graphisoft´s GH connector, I mean, neglected by design. In fact, I would say that they have only taken in consideration the “geometry generation” part of the story, which I personally consider a limiting approach considering GH capabilities for data managing and interfacing with 3rd applications. Nonetheless, I must admit that Graphisoft’s proposal for embedding external data as properties via Excel files works quite well… but quite tedious/manual though… speckle would greatly streamline the whole process.
The excel workflow is indeed doing a great job. However this will hopefully as you say streamline things. We have rignt now a CO2 project which probably could be much smoother with this kind of live access to the database. Very interesting project this Speckle
Hello guys,
This is really awesome. Here in Switzerland, like some other parts in Europe, Archicad is the main tool used by architects and in our lab we use it a lot. We are definitely looking forward to use this connector
Just a question : do we have an approximate timeline for when will we be able to test it ? An alpha version release for example ? We will be delighted to be among the first testers.
Again, thanks for the big news and the great work behind
This is so exciting! Thanks for this big effort. One quick question. Would it be multiplatform or windows only? There’s a big community of Archicad users in Mac.
Thanks again!
