I would find it immensely helpful if you could just add Archicad objects to a model based on the design option it belongs to:
Currently it is doable by creating selections to filter the elements (ctrl+F and set up the search criteria to contain the design option), but I would find it more streamlined and less error prone that way, especially for larger models where a lot of people could send in several options from a teamwork file - I could just tell them to choose the appropriate design option and that’s it.
This would certainly be a powerful function - even more so if it also was possible to compare models (view changes) as it currently is for versions in the viewer.
Your comment activated a memory from probably a Morphosis book almost a decade ago, where there was a huge branch of model evolution presented for a project - I’ll try to find it.
Our next-generation Archicad connector has been developed from the ground up. Currently, it only allows users to Publish models from Archicad to Speckle.
In summary, no, it doesn’t have the feature you requested.
But we have made some changes in the data structure. Please take a look and share your feedback with us.
