ArcGIS Pro connector doesn't show up after installation
Thanks Kateryna! I installed the ArcGIS connector via SpeckleManager, but Speckle doesn’t show up in the Geoprocessing Toolboxes (I never used ArcGIS before so be aware of rookie mistakes on my end).
What can I do to check if the installation was successful?
Hi there! What the installer doing is making a clone of default ArcGIS conda environment (because it doesn’t allow you to modify a default one), and adds a package with Speckle tool there. It it didn’t show up, you can try:
  • restarting ArcGIS (changing active environment will only take place after restarting)
  • check whether environment was successfully cloned and activate it manually via Project - Python - Manage packages. Choose arcgispro-py3-speckle. Restart ArcGIS Pro
Let me know if it resolves the issue!
Thank you for your help and moving it to a new topic!
I don’t see the Speckle python environment.
I was thinking to try the following steps:
  1. Uninstall Speckle ArcGIS connector in Speckle manager
  2. Clone the default environment manually using the Python Package Manager in ArcGIS (this is currently processing and takes some time)
  3. Rename it to “arcgispro-py3-speckle”
  4. Install Speckle ArcGIS connector in Speckle manager
Happy to try other things as well of course
I see!
First question would be, are you using Windows? Installer only works for Windows for now…
If yes, you can uninstall from the manager and install again. When the installer window pops up, first step will be cloning the environment in a new CMD window (usually takes about 5 min for me), could you check whether it shows any errors?
Else, you can do exactly what you suggested, just make sure the environment will be cloned to "C:\Users\ ‘username’ \AppData\Local\ESRI\conda\envs" and called arcgispro-py3-speckle right away, otherwise the installer might not be able to find it.
Yes windows it is.
I got a long list of errors in ArcGIS when trying to “Clone Default”.
Long list of errors
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://conda.anaconda.org/esri/win-64/arcgispro-2.9-0.tar.bz2
Elapsed: -
An HTTP error occurred when trying to retrieve this URL.
HTTP errors are often intermittent, and a simple retry will get you on your way.
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://conda.anaconda.org/esri/win-64/arrow-cpp-1.0.1-3.tar.bz2
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/win-64/blas-1.0-mkl.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://conda.anaconda.org/esri/win-64/icc_rt-2019.0.5-arcgispro_0.tar.bz2
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://conda.anaconda.org/esri/win-64/intel-openmp-2020.0-arcgispro_166.tar.bz2
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://conda.anaconda.org/esri/win-64/libsodium-1.0.18-2.tar.bz2
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://conda.anaconda.org/esri/win-64/nlohmann_json-3.7.0-1.tar.bz2
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://conda.anaconda.org/esri/win-64/openssl-1.1.1k-1.tar.bz2
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://conda.anaconda.org/esri/win-64/pybind11-2.7.1-0.tar.bz2
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://conda.anaconda.org/esri/win-64/pybind11_json-0.2.6-2.tar.bz2
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://conda.anaconda.org/esri/win-64/vs2015_runtime-14.16.27012-hf0eaf9b_0.tar.bz2
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/win-64/winpty-0.4.3-4.tar.bz2
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://conda.anaconda.org/esri/win-64/xeus-0.24.1-3.tar.bz2
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://conda.anaconda.org/esri/win-64/xeus-python-0.8.2-5.tar.bz2
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://conda.anaconda.org/esri/win-64/xtl-0.6.15-0.tar.bz2
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://conda.anaconda.org/esri/win-64/libxml2-2.9.12-arcgispro_0.tar.bz2
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://conda.anaconda.org/esri/win-64/mkl-2020.0-arcgispro_167.tar.bz2
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://conda.anaconda.org/esri/win-64/pyarrow-1.0.1-2.tar.bz2
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/win-64/vc-14.1-h0510ff6_4.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://conda.anaconda.org/esri/win-64/zeromq-4.3.4-0.tar.bz2
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://conda.anaconda.org/esri/win-64/cppzmq-4.4.1-4.tar.bz2
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://conda.anaconda.org/esri/win-64/jpeg-9d-0.tar.bz2
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/win-64/libdeflate-1.8-h2bbff1b_5.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/win-64/libxslt-1.1.34-he774522_0.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/win-64/lz4-c-1.9.3-h2bbff1b_0.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://conda.anaconda.org/esri/win-64/sqlite-3.36.0-0.tar.bz2
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/win-64/xz-5.2.5-h62dcd97_0.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://conda.anaconda.org/esri/win-64/yaml-0.2.5-0.tar.bz2
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/win-64/zlib-1.2.11-h62dcd97_4.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/win-64/libpng-1.6.37-h2a8f88b_0.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/win-64/libprotobuf-3.13.0.1-h200bbdf_0.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://conda.anaconda.org/esri/win-64/python-3.7.11-1.tar.bz2
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/win-64/zstd-1.4.9-h19a0ad4_0.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/noarch/appdirs-1.4.4-py_0.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/noarch/asn1crypto-1.4.0-py_0.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/noarch/atomicwrites-1.4.0-py_0.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/noarch/attrs-21.2.0-pyhd3eb1b0_0.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/noarch/backcall-0.2.0-pyhd3eb1b0_0.tar.bz2
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/win-64/blinker-1.4-py37haa95532_0.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/noarch/cached-property-1.5.2-py_0.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/noarch/cachetools-4.2.2-pyhd3eb1b0_0.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/win-64/certifi-2021.5.30-py37haa95532_0.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/win-64/chardet-4.0.0-py37haa95532_1003.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/noarch/click-7.1.2-pyhd3eb1b0_0.tar.bz2
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/noarch/colorama-0.4.4-pyhd3eb1b0_0.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/noarch/decorator-4.4.2-pyhd3eb1b0_0.tar.bz2
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/noarch/defusedxml-0.7.1-pyhd3eb1b0_0.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/win-64/entrypoints-0.3-py37_0.tar.bz2
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/noarch/et_xmlfile-1.0.1-py_1001.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/win-64/fastcache-1.1.0-py37he774522_0.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://conda.anaconda.org/esri/win-64/freetype-2.10.4-vc14_3.tar.bz2
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://conda.anaconda.org/esri/win-64/future-0.18.2-py37_0.tar.bz2
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/noarch/idna-2.10-pyhd3eb1b0_0.tar.bz2
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/noarch/iniconfig-1.1.1-pyhd3eb1b0_0.tar.bz2
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/noarch/ipython_genutils-0.2.0-pyhd3eb1b0_1.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/noarch/jdcal-1.4.1-py_0.tar.bz2
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/win-64/kiwisolver-1.3.1-py37hd77b12b_0.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://conda.anaconda.org/esri/win-64/libtiff-4.3.0-1.tar.bz2
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/win-64/lxml-4.6.3-py37h9b66d53_0.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/win-64/markupsafe-1.1.1-py37hfa6e2cd_1.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/win-64/mccabe-0.6.1-py37_1.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/win-64/mistune-0.8.4-py37hfa6e2cd_1001.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/win-64/mpmath-1.2.1-py37haa95532_0.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/win-64/mypy_extensions-0.4.3-py37_0.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/noarch/nose-1.3.7-pyhd3eb1b0_1006.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://conda.anaconda.org/esri/win-64/numpy-base-1.20.1-py37_0.tar.bz2
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/win-64/olefile-0.46-py37_0.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/win-64/pandocfilters-1.4.3-py37haa95532_1.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/noarch/parso-0.8.1-pyhd3eb1b0_0.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/noarch/pathspec-0.7.0-py_0.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/noarch/pickleshare-0.7.5-pyhd3eb1b0_1003.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://conda.anaconda.org/esri/noarch/prometheus_client-0.8.0-py_0.tar.bz2
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/win-64/psutil-5.8.0-py37h2bbff1b_1.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/noarch/py-1.10.0-pyhd3eb1b0_0.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/noarch/pycodestyle-2.6.0-pyhd3eb1b0_0.tar.bz2
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/noarch/pycparser-2.20-py_2.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/noarch/pyflakes-2.2.0-pyhd3eb1b0_0.tar.bz2
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/win-64/pyjwt-2.1.0-py37haa95532_0.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/win-64/pyodbc-4.0.30-py37ha925a31_0.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/noarch/pyparsing-2.4.7-pyhd3eb1b0_0.tar.bz2
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://conda.anaconda.org/esri/noarch/pypdf2-1.26.0-py_2.tar.bz2
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/win-64/pyrsistent-0.17.3-py37he774522_0.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/noarch/pyshp-2.1.3-pyhd3eb1b0_0.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://conda.anaconda.org/esri/win-64/pytz-2020.1-py37_0.tar.bz2
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://conda.anaconda.org/esri/win-64/pywin32-ctypes-0.2.0-py37_0.tar.bz2
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://conda.anaconda.org/esri/win-64/pywin32-security-228-py37_3.tar.bz2
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://conda.anaconda.org/esri/win-64/pywinpty-0.5.7-py37_0.tar.bz2
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/win-64/pyyaml-5.4.1-py37h2bbff1b_1.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/win-64/regex-2021.8.3-py37h2bbff1b_0.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/noarch/send2trash-1.5.0-pyhd3eb1b0_1.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/win-64/simplegeneric-0.8.1-py37_2.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://conda.anaconda.org/esri/noarch/six-1.15.0-py_0.tar.bz2
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/win-64/sqlalchemy-1.3.19-py37he774522_0.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/noarch/testpath-0.4.4-pyhd3eb1b0_0.tar.bz2
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/noarch/toml-0.10.2-pyhd3eb1b0_0.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/win-64/tornado-6.1-py37h2bbff1b_0.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/win-64/typed-ast-1.4.2-py37h2bbff1b_1.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/noarch/typing_extensions-3.7.4.3-pyha847dfd_0.tar.bz2
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/win-64/ujson-4.0.2-py37hd77b12b_0.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/noarch/wcwidth-0.2.5-py_0.conda
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://repo.anaconda.com/pkgs/main/win-64/webencodings-0.5.1-py37_1.tar.bz2
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://conda.anaconda.org/esri/win-64/numpy-1.20.1-py37_0.tar.bz2
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://conda.anaconda.org/esri/win-64/netcdf4-1.5.7-py37_arcgispro_2.tar.bz2
Elapsed: -
CondaHTTPError: HTTP 000 CONNECTION FAILED for url https://conda.anaconda.org/esri/win-64/arcpy-2.9-py37_arcgispro_32704.tar.bz2
Elapsed: -
The Speckle folder already exists in that location (next to the just created arcgispro-py3-clone) and contains a bunch of files. So the folder was created earlier this morning when I ran the installer:
When I uninstall and install again via manager, CMD throws a question (which I didn’t got the first time because the folder didn’t exist). The installation appears to behave the same as it did the first time. The first time it closed automatically so below is just an intermediate screenshot. If I manage to grab some errors from CMD I’ll post it.
Side note: I removed a part of the error list otherwise I can’t make the post.
oh no, it seems like a conda issue. The closets solution I found was these 2 options you can try:
Thank you, this looks promising! The best answer in your first URL shares a CMD command that appears to fix the issue because the packages are now being downloaded during the installation:
EDIT: it works, thanks again! :slight_smile:
EDIT 2: I reverted the command and set ssl_verify to true :nerd_face:
Another colleague also had the same issue as me. When entering this command “set ssl_verify false” it worked and then we set it back to true. But this is a hacky work around.
Any thoughts on how the installation process can be improved?
@JdB thanks for bringing this up! From ArcGIS conda issues reported online, it seems as a frequent issue when the default environment cloning cannot be done in ArcGIS even manually. If using ssl verify switch On/Off helps, I can incorporate it in the installer itself. Let me see whether any problems can occur from there.
Another colleague experiences the same issue and they didn’t have conda installed so we couldn’t enter the command. As a work around, we needed to create a file called .condarc in the folder %UserProfile% and temporary set the command in that file. Then installation was possible. (don’t forget to revert the command!)
Hope this helps others as well!
4 posts were split to a new topic: ArcGIS connector doesn’t show up after ArcGIS update
