Perfect, that worked! How do I synchronize the colors of my Treemap graphic with the colors of the modeling? Can it only be done manually? But how do I check which color is right in the model?
Hello!
Following this tutorial, when I put the “volume” in the Tooltip Data, the modeling no longer loads, only the “Speckle” appears and the modeling no longer loads.
Any idea what the problem might be?
Did you set other inputs too? (Model URL, Object ID and Version Object ID inputs)
What version of 3D Visual are you using? If you are using 2.19, I recommend downgrading to 2.18. We had some reports similar to this.
A post was split to a new topic: Colors don’t align with other visuals
Hey @Thiago_Silva ,
Thanks for sharing the file. It helped me understand where the problem lies. Here’s what I found:
I also did a general cleanup on how you extracted data from Records and parameter objects. Here’s my take on your PBI file.
11398-Aligning Colors across visuals.pbix (1.8 MB)
Coloring by volume or any other parameter seems to work just fine.
