Hi community,
Iβd like to share with you an AI assistant specialized in Speckle, a custom LLM that integrates a carefully processed and organized knowledge base.
Knowledge sources
The documentation was distilled from:
All of this content is structured with the Principle β Example β Application methodology, making it easier to move from theory to practice.
How can it be used?
- The documents can be used as an initial context window in any conversation with an LLM (for example, integrated into your own agent or framework).
- They can also be manually attached at the start of a chat with a language model.
- And if you have a ChatGPT Plus subscription, you can use this custom GPT directly, with the documentation already integrated:
Speckle AI GPT
What can this assistant do?
- Answer technical questions about API, connectors, and multi-tool workflows.
- Guide through configurations and common troubleshooting.
- Help integrate Speckle with Power BI and scripting (Python/.NET).
- Provide reproducible and consistent examples.
Full documentation available here:
GitHub Repository β Speckle AI-Ready Docs
Special thanks to @jonathon for his guidance and support.
Feedback and contributions are more than welcome ![]()
