Issue:
I have problem to load the plug-in of Autodesk Forma in Rhino.
The plug-in has a conflict with speckle for Rhino and GH.
When I start Rhino with speckle, Rhino shows Plug-in Error which is connected to the Forma as below image.
Without Speckle, the plug-in for the Forma loads correctly.
After Rhino is on with the Forma, the Speckle for Rhino and GH can be installed again.
But if I turn off and on Rhino again, the same error appears.
This error might not be a problem of speckle, but it would be great if the speckle team can check about it.
I will also request this issue to the Forma.
Best,
Sungbok
