When navigating the model in the 3D online speckle viewer, is it possible to click on an object and select it as camera target?
Additionally, is there a way to change the size of the section box?
Thanks.
Thanks.
Hey @KatherineC ,
You can double-click on an element and it will be set as the camera center. Is this what you are looking for?
Hi @KatherineC
You can change the size of the section box by clicking on the faces of the section box then dragging them to make the box larger/smaller
Cheers
3 posts were split to a new topic: Adding to canonical views from Revity
