I need to assign the Z dimension value present in the attribute table to the line (geometry). However, I only found the option where I will assign only one Z value to all lines present in the shape. And in my case each line will have a different quota.
Hi @Luciana_Rabelo8 ,
You can do so in QGIS Processing Toolbox:
It will allow you to choose the value from the attribute table, per feature:
