I’ve imported with SPECKLE in TEKLA (i work in mm for modeling and drawings) a REVIT model wich has been draw in meter, when i have imported , the scale is not good. No way to change it with SPECKLE settings ?
BR
Hi @NFRERE , I’m sorry to hear that you have a trouble with the Tekla Connector.
The geometry should be scaled to units of receiving application. Is the received model 1000 time smaller than expected? Or is it completely off?
Yes 1 000 times smaller in TEKLA than in REVIT
OK, this doesn’t seem right, we will investigate. Thank you for reporting.
