When will Speckle for Dynamo 2024 be released?
Just curious. The current Speckle Manager only installs upto 2023 Dynamo. I am looking to start using it on a project that is in 2024.
Hey @MichaelRensing ,
Great to see you back!
We currently support Dynamo 2.17 in Revit 2024.
It is on our roadmap to add support for the latest Dynamo version in the coming releases. In the meantime, you can manually copy-paste Speckle into Dynamo plugins folder and it should work just fine. Here’s how:
  1. Open the Windows File Explorer and navigate to this path: C:\Users\{USER}\AppData\Roaming\Dynamo\Dynamo Revit.
  2. You will see multiple folders with different version numbers. Open a folder that corresponds to a previous version.
  3. Open the “packages” folder within that folder and locate the folder named “SpeckleDynamo2” and copy it.
  4. Now paste it into the folder with the latest version number, which should be 2.19 for the 2024 release.
    That’s it! You should be able to use Speckle inside Dynamo now.
