Websocket-disconnected / Websocket client not connected
Hi all,
We have our own speckle server deployed and it’s running. We can acces it, see our steams, create projects etc.
Every things seem fine, but we’re experiencing that Rhino, Grasshopper and Dynamo Senders and Receivers throws websocket warnings at us.
Dynamo Receive & Send
Dynamo fails on sending and receiving Streams.
Grasshopper Receive & Send
Grasshopper gets all Projects and Streams, but fails on sending and receiving.
Speckle UI
The Speckle UI recieves the Streams and they can be viewed.
Server setup
We’ve had IT department looking into this and made them aware of the server block that @dimitrie posted here: https://speckle.community/t/get-a-dockers-url/183/6. This didn’t solve it.
We have a reverse proxy setup and the websockets are now enabled for this.
Versions
Revit 2019.2 and Dynamo 2.3
Rhino 6
Speckle Clients 1.8.5.254
Quick question before we delve into dirty server deployment laundry: do you get the same behaviour with Hestia?
No, the Hestia server works perfectly.
I suspect it’s our setup, but it’s hard for me to troubleshoot this since I know very little about the server setup.
Sorry for me / us being very novice in all this.
Rhino Geo Sent
Server UI Received
Speckle_WebSocket_Hestia_02
Dynamo Received
Grasshopper Received
Hi @martinromby -
I just got done banging my head on the wall about this issue for several days. Where is your server hosted? Ours is on AWS, and the issue for us ended up being the SSL security policy for the load balancer in front of our server.
