What could I write in “select” input to visualize “material” values?
Leaving the field totally empty will visualize all the headers where I can see the material:
Okay @soroush, minor panic moment averted on my end (after some digging ): you just need to put your key name in qoutes, and escape them. Basically, for “@material”, your select clause would be ["\"@material\""]. I know it looks like a monkey threw a spanner in a text input field, but we’re providing raw queries here; ideally we’d build a “query builder” to generate those correctly (part 2 of that tutorial maybe?).
Hi @dimitrie! Oh that kind of makes sense and works well! thanks a lot for checking this.
If I may add a follow up hint ! To make this loading from HelloWorld.vue code, you’d need to use \\ instead of \ !
