"View all" for sub-models in new web app
Objective: I would like to be able to view multiple sub-models together.
Issue: The “View all” button only works for the top-most level stream, but not the sub-level streams.
Example:
I have created a folder structure in which I have several “sample” folder, and then several models inside that contains different part of the building.
See screenshot:
  1. For the “View all” button that works, it shows all the models, but it is not what I want.
    I just want to be able to see the models in sub-folder “Sample_01” or “Sample_02”, not both of them concurrently.
  2. For those that doesn’t work, it gives Error 404.
Could it be that I’m misunderstanding how “View all” in sub-folders/ sub-model works? Please help.
Thank you very much!
Thanks for flagging this issue and sorry for the inconvenience! This has been fixed. You can now view the contents of sub-folders using the ‘View all’ button. Please let us know if you have any problems. :+1:
Thank you so much for the quick response and quick fix! It works perfectly now. Thanks again!
