I have a Speckle Server deployed locally in a Linux machine using docker-compose.yml file. However I am unable to upgrade it to the latest 2.26 version
Below is the yml file
version: "2.3"
services:
# Speckle Server dependencies
reverse-proxy:
image: traefik:v2.10
restart: always
command:
- "--providers.docker=true"
- "--providers.docker.exposedbydefault=false"
- "--entrypoints.websecure.address=:443"
- "--certificatesresolvers.myresolver.acme.tlschallenge=true"
# To use Let's Encrypt staging server instead of production, uncomment the following line
#- "--certificatesresolvers.myresolver.acme.caserver=https://acme-staging-v02.api.letsencrypt.org/directory"
# TODO: replace `{[email protected]}` with your actual email
- "[email protected]"
- "--certificatesresolvers.myresolver.acme.storage=/letsencrypt/acme.json"
# To enable the Traefik web UI (enabled by --api.insecure=true); this is not recommended as it will expose the Traefik dashboard to the internet
#- "--api.insecure=true"
ports:
# The HTTPS port (required for Traefik to listen to HTTPS requests)
- "443:443"
# The Traefik Web UI port if enabled by --api.insecure=true
- "8080:8080"
volumes:
- "./letsencrypt:/letsencrypt"
# So that Traefik can listen to the Docker events
- "/var/run/docker.sock:/var/run/docker.sock:ro"
postgres:
image: "postgres:16.9-alpine"
restart: always
environment:
POSTGRES_DB: speckle
POSTGRES_USER: speckle
POSTGRES_PASSWORD: speckle
volumes:
healthcheck:
# the -U user has to match the POSTGRES_USER value
test: ["CMD-SHELL", "pg_isready -U speckle"]
interval: 5s
timeout: 5s
retries: 30
redis:
image: "valkey/valkey:8-alpine"
restart: always
volumes:
- ./redis-data:/data
ports:
- "127.0.0.1:6379:6379"
healthcheck:
test: ["CMD", "valkey-cli", "--raw", "incr", "ping"]
interval: 5s
timeout: 5s
retries: 30
minio:
image: "minio/minio"
command: server /data --console-address ":9001"
restart: always
volumes:
- ./minio-data:/data
healthcheck:
test: ["CMD", "mc", "ready", "local"]
interval: 5s
timeout: 5s
retries: 5
# Speckle Server
speckle-ingress:
image: speckle/speckle-docker-compose-ingress:2
restart: always
ports: []
# - "0.0.0.0:80:8080"
environment:
FILE_SIZE_LIMIT_MB: "4096"
NGINX_ENVSUBST_OUTPUT_DIR: "/etc/nginx"
labels:
- "traefik.enable=true"
#TODO: replace `example.com` with your domain. This should just be the domain, and do not include the protocol (http/https).
- "traefik.http.routers.speckle-ingress.rule=Host(`XXX.azure.com`)"
- "traefik.http.routers.speckle-ingress.entrypoints=websecure"
- "traefik.http.routers.speckle-ingress.tls.certresolver=myresolver"
- "traefik.http.services.speckle-ingress.loadbalancer.server.port=8080"
speckle-frontend-2:
image: speckle/speckle-frontend-2:2
restart: always
environment:
NUXT_PUBLIC_SERVER_NAME: "local"
# TODO: Change NUXT_PUBLIC_API_ORIGIN to the URL of the speckle server, as accessed from the network. This is the same value as should be used for the CANONICAL_URL in the server section below.
NUXT_PUBLIC_API_ORIGIN: "https://xxx.azure.com"
NUXT_PUBLIC_BACKEND_API_ORIGIN: "http://speckle-server:3000"
# TODO: Change NUXT_PUBLIC_BASE_URL to the URL of the speckle frontend, as accessed from the network. This is the same value as should be used for the CANONICAL_URL in the server section below.
NUXT_PUBLIC_BASE_URL: "https://xxx.azure.com"
NUXT_PUBLIC_LOG_LEVEL: 'warn'
NUXT_REDIS_URL: "redis://redis"
speckle-server:
image: speckle/speckle-server:2
restart: always
healthcheck:
test:
"CMD",
"/nodejs/bin/node",
"-e",
"try { require('node:http').request({headers: {'Content-Type': 'application/json'}, port:3000, hostname:'127.0.0.1', path:'/graphql?query={serverInfo{version}}', method: 'GET', timeout: 2000 }, (res) => { body = ''; res.on('data', (chunk) => {body += chunk;}); res.on('end', () => {process.exit(res.statusCode != 200 || body.toLowerCase().includes('error'));}); }).end(); } catch { process.exit(1); }",
interval: 10s
timeout: 3s
retries: 30
depends_on:
postgres:
condition: service_healthy
redis:
minio:
environment:
CANONICAL_URL: "https://xxx.azure.com"
SPECKLE_AUTOMATE_URL: "http://127.0.0.1:3030"
S3_ENDPOINT: "http://minio:9000"
S3_ACCESS_KEY: "minioadmin"
S3_SECRET_KEY: "minioadmin"
S3_BUCKET: "speckle-server"
S3_CREATE_BUCKET: "true"
FILE_SIZE_LIMIT_MB: 100
# TODO: Change this to a unique secret for this server
SESSION_SECRET: "$peckle@2o25"
STRATEGY_LOCAL: "true"
DEBUG: "speckle:*"
POSTGRES_URL: "postgres"
POSTGRES_USER: "speckle"
POSTGRES_PASSWORD: "speckle"
POSTGRES_DB: "speckle"
ENABLE_MP: "false"
FRONTEND_ORIGIN: "https://xxx.cloudapp.azure.com"
preview-service:
image: speckle/speckle-preview-service:2
restart: always
depends_on:
speckle-server:
mem_limit: "1000m"
memswap_limit: "1000m"
environment:
DEBUG: "preview-service:*"
PORT: "3001"
webhook-service:
image: speckle/speckle-webhook-service:2
restart: always
depends_on:
speckle-server:
environment:
DEBUG: "webhook-service:*"
PG_CONNECTION_STRING: "postgres://speckle:speckle@postgres/speckle"
WAIT_HOSTS: postgres:5432
fileimport-service:
image: speckle/speckle-fileimport-service:2
restart: always
depends_on:
speckle-server:
environment:
DEBUG: "fileimport-service:*"
SPECKLE_SERVER_URL: "http://speckle-server:3000"
networks:
default:
volumes:
postgres-data:
redis-data:
minio-data:
It would be be really helpfull if someone can let me know the exact version of the different services that needs to be configured in the yml file in order to upgrade the speckle server to the latest build
