Does anyone know of any examples of creating a commit to modify objects from a web client.
For example if I want to add/edit a Speckle object in a web client, do I need to be using the GraphQL API directly. Is there a JS API similar to Python/C#?
Hi @kgoulding! Unfortunately not. There is a way to create objects directly from the gql api (via the objectCreate mutation), nevertheless there’s a bit of legwork required and you need to exercise caution, especially if you modify an object inside a larger tree (inside another object), as all the correct closures need to be “handcrafted” and updated. This is easy inside a collection wrapper, but more difficult in a more structured object.
What’s your direct use case? If something easy, we can try and write a quick POC.
You’ll have to watch David’s presentation tomorrow for the full use case
Basically we are pulling polylines into a Google Map and then want to be able to trace elements on an aerial to pull back into a Speckle Stream (destination CAD / Rhino).
Another use case would be adding metadata to the geometry (e.g. classifications for landuse/density) that we’d want to persist in the stream.
Will definitely tune in for @haitheredavid 's show
I gotcha - use cases are clear. Creating from scratch shouldn’t be a problem, but a mini SDK wouldn’t hurt here. @izzylys has some incipient stuff in JS that was born for the SketchUp connector’s needs (mini spoiler here). Let’s regroup after the conf and work things out!
You could have a look at how we create Globals as well:
