Hoy!
This might be a Rhino.Inside or a Speckle bug
I’m using Grasshopper/Rhino Inside in Revit and read some Revit-geometry.
My Rhino-unit is mm
See picture.
When I read the stream in Grasshopper (outside Revit), the numeric description is in mm, while the brep/curve sizes gets multiplied by 1000.
When i Change the Rhino-unit size to m, the numeric and the geometric size correspond.
