hi,
I am able to connect to the speckle server below and i can see that my message is sent apparently. I am able to receive messages from the speckle web server. However i can not unpack what is being sent on another ws client connected and listening to the same stream… so i cannot tell if the message i’m trying to send onOpen() works is valid… i’m guessing not despite converting it to a json string
I’m using WebSocketSharp and Newtonsoft.Json libraries in c#.
using System;
using System.Collections.Generic;
using WebSocketSharp;
using System.Text;
using Newtonsoft.Json;
namespace SpkConsole
partial class Program
static void Main(string[] args)
string ClientId = Guid.NewGuid().ToString();
string AuthToken = "JWT+myjwt";
string StreamId = "0HPUn-dvE";
WebSocket WebsocketClient = new WebSocket("wss://hestia.speckle.works?access_token=" + AuthToken + "&stream_id=" + StreamId + "&client_id=" + ClientId);
WebsocketClient.OnMessage += (sender, e) => Console.WriteLine("computer says: " + e.Data);
WebsocketClient.OnOpen += (sender, e) => {
Dictionary<string, object> message = new Dictionary<string, object>();
message["eventType"] = "broadcast";
message["senderId"] = ClientId;
message["resourceType"] = "stream";
message["resourceId"] = StreamId;
message["args"] = new Dictionary<string, string>
{ "stream" , "KiAKG2AsS"},
{ "action" , "update_mesh"}
WebsocketClient.Send(JsonConvert.SerializeObject(message));
Console.WriteLine("just sent: " + JsonConvert.SerializeObject(message));
WebsocketClient.OnError += (sender, e) => Console.WriteLine("Error: " + e.Message);
WebsocketClient.OnClose += (sender, e) => Console.WriteLine("Closing: " + e.Reason);
WebsocketClient.ConnectAsync();
Console.ReadLine();
Hola @pathespe! Sorry for the delay. But I got something running, based on SpeckleCore’s ApiClient ws methods.
I’ll admit, it’s a bit of a pain.
using System;
using System.Threading;
using SpeckleCore;
using SpkConsole;
namespace SpkWsExample
class Program
Console.WriteLine("Hello Smelly Sockets");
var account = SpkConsole.Program.GetAccount();
var spkClient_A = new SpeckleApiClient(account.RestApi, false, "console application");
var spkClient_B = new SpeckleApiClient(account.RestApi, false, "console application");
spkClient_A.AuthToken = account.Token;
spkClient_B.AuthToken = account.Token;
//gen streamid
var streamId = spkClient_A.StreamCreateAsync(new SpeckleStream() { Name = "WS Test" }).Result.Resource.StreamId;
Console.WriteLine($"Created dummy stream: {streamId}. Press any key to continue stuff.");
// Add event handlers and setup streamId on both ws clients. The event handlers just spit out what they get.
spkClient_A.StreamId = streamId;
spkClient_A.SetupWebsocket();
spkClient_A.OnWsMessage += SpkClient_A_OnWsMessage;
spkClient_B.StreamId = streamId;
spkClient_B.SetupWebsocket();
spkClient_B.OnWsMessage += SpkClient_B_OnWsMessage;
Console.WriteLine("Waiting for 200ms, ensure connection actually happened. This is an issue with core, it doesn't expose a 'onwsconnection' event :/");
Thread.Sleep(200);
// Flop them in a room - this is important if you want to broadcast messages.
spkClient_A.JoinRoom("stream", streamId);
spkClient_B.JoinRoom("stream", streamId);
// Same hack as above.
Thread.Sleep(200);
// Send some dummy broadcasts
spkClient_A.BroadcastMessage("stream", streamId, new { customEventType = "update-mesh", data = "42" });
spkClient_A.BroadcastMessage("stream", streamId, new { customEventType = "update-mesh-other", data = "wow" });
spkClient_B.BroadcastMessage("stream", streamId, new { customEventType = "update-mesh-other", data = "wow" });
spkClient_B.SendMessage(spkClient_A.ClientId, new { what = "This is a direct, 1-1 message from B to A." });
Console.WriteLine("Press any key to continue.");
Console.ReadLine();
private static void SpkClient_B_OnWsMessage(object source, SpeckleEventArgs e)
// Note, the dynamic object with the "parsed" event data is in e.EventObject.
Console.WriteLine();
Console.WriteLine($"(Client B) Event name: {e.EventName}; Raw: {e.EventData}.");
private static void SpkClient_A_OnWsMessage(object source, SpeckleEventArgs e)
Console.WriteLine($"(Client A) Event name: {e.EventName}; Raw: {e.EventData}.");
Solved this one for extra points too
The original approach was ok, just malformed…
// what i changed: just this! it should pop up in other subscribed clients.
var eventData = new
eventName = "broadcast",
senderId = ClientId,
resourceType = "stream",
resourceId = DummyStreamId,
args = new
hello="world",
source="random client"
WebsocketClient.Send(JsonConvert.SerializeObject(eventData));
Console.WriteLine("just sent: " + JsonConvert.SerializeObject(eventData));
ahh so close. thanks for this, would double like if i could. exactly what im after
