Unable to load Speckle
I faced this problem while after installing specke!
Rhino 7 SR28 2023-2-10 (Rhino 7, 7.28.23041.13001, Git hash:master @ 78b4312dc75e2b5005bc7cc69a35c7cf10e4970e)
License type: Evaluation, build 2023-02-10
License details: Cloud Zoo
Expires on: 2023-05-01
Windows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 16Gb)
Computer platform: LAPTOP - Plugged in [58% battery remaining]
Non-hybrid graphics configuration.
Primary display and OpenGL: NVIDIA GeForce RTX 3070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 9-21-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 517.48
> Integrated accelerated graphics device with 4 adapter port(s)
- Windows Main Display is laptop’s integrated screen or built-in port
OpenGL Settings
Safe mode: Off
Use accelerated hardware modes: On
Redraw scene when viewports are exposed: On
Graphics level being used: OpenGL 4.6 (primary GPU’s maximum)
Anti-alias mode: 2x
Mip Map Filtering: Linear
Anisotropic Filtering Mode: High
Vendor Name: NVIDIA Corporation
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 9-21-2022
Driver Version: 31.0.15.1748
Maximum Texture size: 32768 x 32768
Z-Buffer depth: 24 bits
Maximum Viewport size: 32768 x 32768
Total Video Memory: 8 GB
Rhino plugins that do not ship with Rhino
C:\Users\user\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\D5Conv (e0d5e210-02f6-4ee9-a2b0-1675e225d958)\0.11.0.0004\Rhino 7\D5Conv.rhp “D5Converter for Rhino”
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp “Datasmith Exporter” 5.1.0.0
C:\Users\user\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.22334.1442
C:\Users\user\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\KeyShot11RhinoPlugin (55124e8a-aa81-4be8-8e12-9f452c473970)\1.0.0.0\KeyShot11RhinoPlugin\Rhino 7\KeyShot11RhinoPlugin.rhp “KeyShot11RhinoPlugin” 1.0.0.0
C:\Program Files\RhinoNestRhino6\System\RhinoNest.rhp “RhinoNest” 4.6.18354.2
C:\Users\user\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\Fologram for Rhino (468a328b-20d9-494b-b9e1-cbe9f827d3a2)\2020.3.5.0\7\Fologram.IO.Rhino3d.Win7.rhp “Fologram for Rhino” 2020.3.5.0
C:\ProgramData\Beam\App\RHINOBEAM.dll “MKS BEAM” 1.9.0.0
C:\Users\user\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\ColorPicker\6.0.0\ColorPicker.rhp “ColorPicker”
C:\Users\user\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\EleFront\4.2.2\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Users\user\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
C:\Program Files\Rhino 7\Plug-ins\Karamba\License\Karamba3D_LicensePlugin_Rhino7.rhp “Karamba3DLicense”
Rhino plugins that ship with Rhino
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.28.23041.13001
C:\Users\user\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2021.3.2.446\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.28.23041.13001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.28.23041.13001
C:\Program Files\Rhino 7\Plug-ins\rdk_ui.rhp “Renderer Development Kit UI”
C:\Program Files\Rhino 7\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.28.23041.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.28.23041.13001
C:\Program Files\Rhino 7\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino 7\Plug-ins\Displacement.rhp “Displacement”
Hi @Hussein_Hamed!
Thanks for reporting this! Just to confirm, what version of the Rhino connector are you running? The latest should be 2.12.2.
I tested on my machine but couldn’t manage to reproduce your issue, we may need to look a little deeper to find the cause of this.
Thanks for all the extra error info, it will be super helpful as sometimes this initialisation issues are caused by conflicts between plugins.
EDIT:
This may also happen if you have 2 versions of the connector in your computer. This could be the case if you ever downloaded the connector code and built it from source, and later installed the Manager version.
Yes, I have downloaded the latest version Today
Maybe I have installed Speckle for Rhino 3 month ago I think,I can’t remember.
@AlanRynne Speckle plugin is workign with rhino 6 and the problem persist with rhino 7
Hey @Hussein_Hamed! Thanks for coming back to us, and I’m sorry for the troubles you’re having.
Did you manage to update your Rhino 7 version? What version are you running right now?
I’ll try to roll back to your specific version and check if I can reproduce this consistently :wink:
I have tried multiple updates but the problem persist
I’m using Version 7 SR28
(7.28.23058.3001, 2023-02-27)
@AlanRynne
