Unable to Automatically Refresh 3D model in PBI
I would like to check if it’s possible to schedule refresh for the 3D model in PBI? I tried but seems don’t support the auto refresh. The 3D model is created by SketchUp. Viewer is Speckle Power BI 3D Visual. Thanks.
Regards
Judy
Hi @judywu0102,
Could you explain more auto refresh behavior that you would like to have? If you meant the auto refresh once you have new version, this is not possible since the data managed by PowerBI data connector, not with PowerBI visual. But you should be able to refresh from PowerBI by clicking the a single button as explained here Refresh semantic models created from local Power BI Desktop files - Power BI
Did you have a chance to check our new PowerBI connector? I would highly recommend to try it. You can find it here speckle-releases
Best
Hey @judywu0102,
I believe this is expected since Speckle is a custom connector and not an out-of-the-box connector for Power BI. As far as I know, scheduled refreshes are only available for default connectors.
