Trouble loading the Blender connector
Hi @Arq4ngel
Sorry to hear you’re having issues.
Do you receive any error messages when you try and enable the add on?
Please could you also follow these steps:
  1. Open a blender.
  2. Open the system Console (Window -> Toggle System Console)
    blender-system-console
  3. Open the Addons tab, and try enable the Speckle addon.
  4. Copy paste the text from the system console, and post it here.
Additionally, please could you let me know if you have any other third party Blender add ons installed.
Here I saw this on the console, I captured this part which are some exceptions. You still see a warning, but after trying several times, the connector finally installed
Hi @Arq4ngel
From the looks of those logs, There could be a conflict between our Speckle plugin and another thirdparty plugin you have installed.
If you continue to have issues, I would suggest dissabling other third party plugins and re-enabling them one by one to find the conflict.
There’s a chance that a newer (or sometimes older) version of a plugin can be found that will be compatible with our addon
The 1st time I activated it in the Blender preferences, it gave me an error, the 2nd too, and the 3rd the same, but the next day I tried it and it activated fine, maybe I should have restarted the computer. Although it is true that the warning persists, I have tested the add-on receiving several Revit models and it works perfectly, it has exceeded my expectations, very well organized, fast, precise positioning the different objects of work.Thank you. Good job.
