I’m trying to bring geometry from Rhino to Revit, In the video below you can see that I can bring the geometry in fine using RhinoInside. When I use Speckle, the geometry is triangulated, is there a way to avoid this? (bonus content, if you try and receive Speckle in Revit with RhinoInside + Rhino.Speckle open it crashes haha, but that’s a silly workflow anyways):
It seems that something is failing when trying to create that Brep in Revit. When a solid fails to be created, the connector will default to the mesh representation of that geometry (this will ensure that you actually receive something, as opposed to just not showing any result in the target application
We’re aware that Revit users quite hate how it displays meshes (we do to…) so we’re happy to have a look to see if we can fix this.
Since Breps are quite a complex thing, it’s difficult for us to test all possible cases. I’m hoping you could help us with that! Would it be possible to share with us the original Brep and the stream you are using to send it to Revit? (You can do so over private message if you prefer)
Turns out a small bug was introduced in the latest version that prevented Arc curves from being re-generated with the proper units (defaulted to meters…) which was the reason for this behaviour you reported (and a couple other users from the forum too!)
I’ll be merging the fix in today, so you’ll have it on the next release! If you need it sooner, you can always tell the manager to notify you about beta releases of connectors, which have a faster release cycle
Hey Johan!! Nice to hear from you!!! I hope everything is well
Thanks for reporting this!! I’m not sure what could be happening there, could you send me the file you are using (or the parts that are breaking) and share the stream url with me too? I’ll try and reproduce exactly that behaviour.
No need to apologise for the long post! We love well reported errors As this does seem to be a completely different issue than the original. I’ll open a new GitHub issue for it.
Hi @Johan_Navarro_MA , quick update to say that I’ve looked into this and you are correct, RhinoBIM was not handling extrusions. Just finished adding extrusion support with our upcoming 2.2.3 release, thanks for being patient for the fix!
