Tooltip data still not working in 3d visual v2.19.0
Hello dear Team,
The master’s thesis deadline falls within this month and the tooltip-data function remains non-functional even after reverting to Speckle Power BI Viewer version 2.19.0. It is suspected that a configuration error may have been introduced during setup. A review of the tooltip-data settings is requested to identify any misconfiguration. Is it possible to verify whether this issue is not due to my own error—did I do something wrong?
As far as i know due to the renaming form globalid to applicationid this problem occured. In my previous PowerBI modells where i have the old upload versions of the ifcs i could use the tooltip data.
I even though try to impent current modells beside the old Modell the tooltip data still dont work.
Kind regards Screenshots:
File:
TSD-Tool_Variante 1_pbi.pbix (1.3 MB)
Speckle plugin version 2.19:
powerbiSpeckleVisual-2.19.0.pbiviz (915.2 KB)
Setting for PowerBI Visual:
Speckle.pqx (44.4 KB)
Speckle Power BI 3D Visual.pbiviz (895.6 KB)
Selam Hakan,
Thanks for sharing the Power BI file. It’s not working because you haven’t filtered the DataObjects from your Query. So when you select an element in the viewer, it only selects the DataObjects itself, not the “Mesh” representation. When you filter out anything non-DataObject, Tooltip seems to be working just fine.
