I want to know if the speckle platform supports the ‘css3object’ in Threejs. I tried importing this class to use it, but it doesn’t seem to render.
Here is an example that uses CSS2DRenderer from three.js.
The speckle viewer will work with stock three.js objects, you just need to set their layer to one of the viewer’s ObjectLayers otherwise it will not render
