Hello. can’t use / create any streams in Revit 2022.
SpeckleCoreLog20240326.txt (344.6 KB)
Hi @EuLoooo
The request is failing with the response code “Forbidden”
This normally implies that either you don’t have access to the private stream (in which case, you should ask the owner for an invite), or the stream doesn’t exist.
Since you mention you’re having trouble even creating streams. I would suggest removing and re-adding your account inside Speckle Manager.
