I’m getting an error “Unit System is unsupported” when trying to send elements from the Revit connector to Speckle.xyz. Looks like it works beautifully for a project that either was started using metric or was changed to use metric after it was started in Imperial units.
Speckle Manager version v2.0.27
Speckle Revit version 2.1.8 & 2.1.9-beta (tested both)
Dynamo Connector 2.1.9-beta
Revit 2020
Windows 10
I saw somewhere (can’t find the thread now) that the issue may have to do with Rhino.Inside.Revit, I have tested it on a computer with Rhino.Inside (and many other plugins installed) as well as on a different machine with a “clean” install of Revit and I’m getting the same error. In Dynamo the error simply says something like “Cannot convert type Revit.Element.Walls to Speckle Object.”
Would love to be able to use Speckle on some U.S. work- thanks in advance for any help!
The full error message from the Revit Connector is below:
The current Unit System is unsupported.
at Objects.Converter.Revit.ConverterRevit.UnitsToSpeckle(DisplayUnitType type)
at Objects.Converter.Revit.ConverterRevit.get_ModelUnits()
at Objects.Converter.Revit.ConverterRevit.CurveToSpeckle(Curve curve, String units)
at Objects.Converter.Revit.ConverterRevit.LocationToSpeckle(Element revitElement)
at Objects.Converter.Revit.ConverterRevit.WallToSpeckle(Wall revitWall)
at Objects.Converter.Revit.ConverterRevit.ConvertToSpeckle(Object object)
at Speckle.ConnectorRevit.UI.ConnectorBindingsRevit.d__9.MoveNext() in C:\Users\circleci\project\ConnectorRevit\ConnectorRevit\UI\ConnectorBindingsRevit.Send.cs:line 85
