Structural Material and Slab Object Kit GH / ETABS
  • Objective: I am trying to generate multiple materials, for sending from GH to ETABS a concrete Slab and a DeckFilled.
  • Issue: The Element2D is generated but the Concrete material is not. Therefore in ETABS the Slab property is not created and the object appears as “Section Property: None”.
  • Example:
  • Speckle link: Speckle
Thanks for reporting @giuliacavallari . Our next release will be focused on structural connectors and this issue will be fixed soon.
I assume you will bring that model from ETABS to Revit in your workflow. If so, would you need these material properties also in Revit?
Hi Pavol, understood thanks for the reply. Yes that would be the ideal scenario
