I’m just trying to work with the v2 rest api and am unable to get it working after following the docs to Downloading a list of objects here: REST API | Speckle Docs
I notice it says:
“”" Parameters:
objects (string): An array of object ids, serialized as a JSON string
but I’m not sure how I’m supposed to get a list of object IDs, before downloading a list of objects that belong to that stream.
I might end up using the SDK for python stuff, but since I’ll be doing JS stuff as well, I just wanted to play around and get an idea of what’s changed in v2.
I still don’t understand how to list all objects that are in a stream. In this example, it seems the child objects are already available and we’re just asking for those objects in particular. But what if I just have a stream ID and want to grab all child objects?
Looking at the SDK I also noticed that the authentication header needs to have "Bearer " before the token, which I think I did try, but good to know for sure.
Given a stream id you can get its latest commit’s root object, from there you need to go through the closure table to get the children object ids… @dimitrie or @izzylys or @cristi can elaborate a bit more!
This you can’t - V1 streams are now commits - this little mental switch might help! To get all the objects in a stream, you’ll need to first get all its commits, and then proceed to get their object’s children.
Also to bear in mind data inside a commit (v1 stream) is not a flat list of objects anymore, it’s actually an object graph (tree), and there’s two ways which you can go through it:
raw dump of all the children via the rest endpoints, and reconstruct the object graph on the receiving end as you deserialise (this is what our sdks do for you)
interactive drilling into it, which you can do via the graphql api (basically like we’re doing in the data explorer in the frontend)
