Speckle to Etabs - 'Sequence contains no matching element'
I am trying to send an analytical model from Revit 2025 across to Etabs 22.
Upon attempting to receive the model in Etabs I receive the following error:
“Sequence contains no matching element”
I have tried to remove and reinstall the plugin with no success. All analytical elements were selected in Revit when the send process was completed. The model appears in the Speckle dashboard without any errors but I cannot get in across into the Etabs software.
Any help would be much appreciated.
Etabs error
Hey @alicdh! :smiley_spockle:
Welcome to the community and thanks for sharing here. Currently, the ETABS connector supports up to and including v21 of ETABS. Do you have a v21 license that you can test on? This will work for your workflow :slight_smile:
