dvalent
(David Valent)
14 June 2023 09:43
1
Hello Specklers,
I’m encountering an error while running Speckle with Docker, and I would greatly appreciate any assistance or insights to help me resolve it. It started with a 502 error on the front end but upon investigating at docker-compose up the error message I’m seeing is as follows:
speckle-server_1 | node:internal/modules/cjs/loader:1078
speckle-server_1 | throw err;
speckle-server_1 | ^
speckle-server_1 |
speckle-server_1 | Error: Cannot find module '/speckle-server/packages/server/bash'
speckle-server_1 | at Module._resolveFilename (node:internal/modules/cjs/loader:1075:15)
speckle-server_1 | at Module._load (node:internal/modules/cjs/loader:920:27)
speckle-server_1 | at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:81:12)
speckle-server_1 | at node:internal/main/run_main_module:23:47 {
speckle-server_1 | code: 'MODULE_NOT_FOUND',
speckle-server_1 | requireStack: []
speckle-server_1 | }
speckle-server_1 |
speckle-server_1 | Node.js v18.16.0
as of today we pulled the latest server and front-end. any ideas what this could be?
Hi @dvalent
We recently made changes to the entrypoint of the Docker image, so the command for starting it is a little different.
Did you update your docker-compose file to the latest published version? I assume you may be using the one from our documentation: Deploying a Server - manual setup | Speckle Docs
EDIT: when updating docker-compose, please backup the database following this guide: Database backup, upgrade, and restore | Speckle Docs
Iain
dvalent
(David Valent)
14 June 2023 10:29
3
Havent tried the latest docker-compose file, ill give that a go. Is the one on the docs up-to-date or is there a github link?
Please use the one in the docs, it has been updated to reflect the change. Please do let me know if this resolves the problem for you!
dvalent
(David Valent)
14 June 2023 15:40
5
Hi Iain,
I’ve used the latest docker-compose.yml file in the docs and that seems to have solved the network issue.
note:
i had to comment out line 63 as it was giving me an ‘unhealthy container’
healthcheck:
test: ["CMD", "node", "-e", "require('node:http').request({headers: {'Content-Type': 'application/json'}, port:3000, hostname:'127.0.0.1', path:'/graphql?query={serverInfo{version}}', method: 'GET' }, (res) => { body = ''; res.on('data', (chunk) => {body += chunk;}); res.on('end', () => {process.exit(res.statusCode != 200 || body.toLowerCase().includes('error'));}); }).end();"]
Front-end and Server spin up without a problem. Unfortunately now my database seems to be completely empty (new) is this possible? would this move create a new db?
gergo
(Gergő Jedlicska)
15 June 2023 08:15
6
Hey @dvalent if you had a volume mapped to your database container it should have your old data.
The new compose file might be referring / creating a different docker volume, so that is why it looks empty.
Also if you are having issues with your database connection, the server won’t report healthy on the healthcheck test.
Could u send a screenshot of your old and new volume references for the DB?
Also note the docker compose volumes are namespaced to the project name.
You can get the existing docker volumes with docker volume ls. Make sure your new compose file is referencing the old volume.
dvalent
(David Valent)
15 June 2023 10:10
7
Hi Gergo, i thought so too.
our old yml file was using this for postgres
postgres:
image: "postgres:13.1-alpine"
restart: always
environment:
POSTGRES_DB:
POSTGRES_USER:
POSTGRES_PASSWORD:
volumes:
ports:
- "127.0.0.1:5432:5432"
redis:
image: "redis:6.0-alpine"
restart: always
volumes:
- ./redis-data:/data
ports:
- "127.0.0.1:6379:6379"
minio:
image: "minio/minio"
command: server /data --console-address ":9001"
restart: always
volumes:
- ./minio-data:/data
ports:
- "127.0.0.1:9000:9000"
- "127.0.0.1:9001:9001"```
compared to the new one from your docs.
postgres:
image: 'postgres:14.5-alpine'
restart: always
environment:
POSTGRES_DB:
POSTGRES_USER:
POSTGRES_PASSWORD:
volumes:
- postgres-data:/var/lib/postgresql/data/
healthcheck:
# the -U user has to match the POSTGRES_USER value
test: ["CMD-SHELL", "pg_isready -U speckle"]
interval: 5s
timeout: 5s
retries: 30
redis:
image: 'redis:6.0-alpine'
restart: always
volumes:
- redis-data:/data
healthcheck:
test: [ "CMD", "redis-cli", "--raw", "incr", "ping" ]
interval: 5s
timeout: 5s
retries: 30
minio:
image: 'minio/minio'
restart: always
volumes:
- minio-data:/data
healthcheck:
test: ["CMD-SHELL", "curl -s -o /dev/null http://127.0.0.1:9000/minio/index.html"]
interval: 5s
timeout: 30s
retries: 30
start_period: 10s
i can see the mapped volumes are virtually the same, ill try to investigate why the the server is failing the health check - anything in particular I should look for?
this is a docker volume ls:
DRIVER VOLUME NAME
local speckv2_minio-data
local speckv2_postgres-data
local speckv2_redis-data
dvalent
(David Valent)
15 June 2023 11:24
8
Checking out the logs I found this error when looking at the server, might be the culprit…
2023-06-15 11:19:28.010 UTC [1] DETAIL: The data directory was initialized by PostgreSQL version 13, which is not compatible with this version 14.5
This is likely to be the problem!
We have a guide on backing up and upgrading the postgres database which should help resolve this: Database backup, upgrade, and restore | Speckle Docs
dvalent
(David Valent)
15 June 2023 12:57
10
All working now,
changed the image back to our previous 13 version
thanks for the link, we will prepare for a migration.
