I tried today to do step by step again:
wsl --install Ubuntu-22.04
git clone
sudo apt-get update
sudo apt-get install gcc g++ cmake // this is not in instruction but without it there is an error that compiler version can’t be detected during “yarn”)
nvm install 18
corepack enable
yarn
yarn build
It just said done without errors
After that I setup docker
yarn dev:docker:up
cp packages/server/.env-example packages/server/.env
cp packages/server/.env.test-example packages/server/.env.test
cp packages/frontend-2/.env.example packages/frontend-2/.env
cp packages/dui3/.env.example packages/dui3/.env
yarn dev
But still it failed to start
5:51:14 PM - Starting compilation in watch mode...
[@speckle/monitor-deployment]: [build:tsc:watch]
[@speckle/preview-service]: [run:watch] (node:4604) ExperimentalWarning: `--experimental-loader` may be removed in the future; instead use `register()`:
[@speckle/preview-service]: [run:watch] --import 'data:text/javascript,import { register } from "node:module"; import { pathToFileURL } from "node:url"; register("./dist/src/aliasLoader.js", pathToFileURL("./"));'
[@speckle/preview-service]: [run:watch] (Use `node --trace-warnings ...` to show where the warning was created)
[@speckle/objectloader]: (!) Unresolved dependencies
[@speckle/objectloader]: guide/en/warning-treating-module-as-external-dependency
[@speckle/objectloader]: #lodash (imported by src/index.js)
[@speckle/objectloader]: created dist/objectloader.esm.js, dist/objectloader.cjs in 5.2s
[@speckle/monitor-deployment]: [run:watch] (node:4616) ExperimentalWarning: `--experimental-loader` may be removed in the future; instead use `register()`:
[@speckle/monitor-deployment]: [run:watch] --import 'data:text/javascript,import { register } from "node:module"; import { pathToFileURL } from "node:url"; register("./dist/src/aliasLoader.js", pathToFileURL("./"));'
[@speckle/monitor-deployment]: [run:watch] (Use `node --trace-warnings ...` to show where the warning was created)
[@speckle/frontend-2]: [0]
[@speckle/frontend-2]: [0] ➜ Local: 127.0.0.1:8081/
[@speckle/frontend-2]: [0] ➜ Network: use --host to expose
[@speckle/monitor-deployment]: [run:watch] INFO: Initializing Prometheus metrics... {"component":"monitor-deployment"}
[@speckle/monitor-deployment]: [run:watch] INFO: Initializing monitoring metrics... {"component":"monitor-deployment"}
[@speckle/monitor-deployment]: [run:watch] INFO: 📊 Started Database monitor server {"component":"monitor-deployment/server"}
[@speckle/monitor-deployment]: [run:watch] INFO: Listening on port 9092 {"component":"monitor-deployment/server"}
[@speckle/dui3]: [0]
[@speckle/dui3]: [0] > Local: localhost:8082/
[@speckle/dui3]: [0] > Network: 172.18.0.1:8082/
[@speckle/dui3]: [0] > Network: 172.23.245.106:8082/
[@speckle/server]: [gqlgen] [STARTED] Parse Configuration
[@speckle/server]: [server] INFO: 🖼️ Serving for frontend-2... {"phase":"startup"}
[@speckle/preview-service]: [build:webpack:watch] [BABEL] Note: The code generator has deoptimised the styling of /home/ambr/speckle-server/packages/viewer/dist/index.js as it exceeds the max of 500KB.
[@speckle/fileimport-service]: ERROR: Error executing task {"component":"fileimport-service"}
[@speckle/fileimport-service]: err: {
[@speckle/fileimport-service]: "type": "DatabaseError",
[@speckle/fileimport-service]: "message": "\n UPDATE file_uploads\n SET\n \"convertedStatus\" = 1,\n \"convertedLastUpdate\" = NOW()\n FROM (\n SELECT \"id\" FROM file_uploads\n WHERE \"convertedStatus\" = 0 AND \"uploadComplete\" = 't'\n ORDER BY \"convertedLastUpdate\" ASC\n LIMIT 1\n ) as task\n WHERE file_uploads.\"id\" = task.\"id\"\n RETURNING file_uploads.\"id\"\n - relation \"file_uploads\" does not exist",
[@speckle/fileimport-service]: "stack":
[@speckle/fileimport-service]: error:
[@speckle/fileimport-service]: at Object.raw (/home/ambr/speckle-server/node_modules/knex/lib/knex-builder/make-knex.js:115:30)
[@speckle/fileimport-service]: at Function.value (/home/ambr/speckle-server/node_modules/knex/lib/knex-builder/make-knex.js:91:29)
[@speckle/fileimport-service]: at startTask (/home/ambr/speckle-server/packages/fileimport-service/src/daemon.js:36:31)
[@speckle/fileimport-service]: at doStuff (/home/ambr/speckle-server/packages/fileimport-service/src/daemon.js:361:26)
[@speckle/fileimport-service]: at async main (/home/ambr/speckle-server/packages/fileimport-service/src/daemon.js:386:3)
[@speckle/fileimport-service]: "length": 111,
[@speckle/fileimport-service]: "name": "error",
[@speckle/fileimport-service]: "severity": "ERROR",
[@speckle/fileimport-service]: "code": "42P01",
[@speckle/fileimport-service]: "position": "13",
[@speckle/fileimport-service]: "file": "parse_relation.c",
[@speckle/fileimport-service]: "line": "1449",
[@speckle/fileimport-service]: "routine": "parserOpenTable",
[@speckle/fileimport-service]: "originalStack": "error: \n UPDATE file_uploads\n SET\n \"convertedStatus\" = 1,\n \"convertedLastUpdate\" = NOW()\n FROM (\n SELECT \"id\" FROM file_uploads\n WHERE \"convertedStatus\" = 0 AND \"uploadComplete\" = 't'\n ORDER BY \"convertedLastUpdate\" ASC\n LIMIT 1\n ) as task\n WHERE file_uploads.\"id\" = task.\"id\"\n RETURNING file_uploads.\"id\"\n - relation \"file_uploads\" does not exist\n at Parser.parseErrorMessage (/home/ambr/speckle-server/node_modules/pg-protocol/dist/parser.js:287:98)\n at Parser.handlePacket (/home/ambr/speckle-server/node_modules/pg-protocol/dist/parser.js:126:29)\n at Parser.parse (/home/ambr/speckle-server/node_modules/pg-protocol/dist/parser.js:39:38)\n at Socket.<anonymous> (/home/ambr/speckle-server/node_modules/pg-protocol/dist/index.js:11:42)\n at Socket.emit (node:events:517:28)\n at addChunk (node:internal/streams/readable:368:12)\n at readableAddChunk (node:internal/streams/readable:341:9)\n at Readable.push (node:internal/streams/readable:278:10)\n at TCP.onStreamRead (node:internal/stream_base_commons:190:23)"
[@speckle/fileimport-service]: }
[@speckle/ui-components]: @storybook/cli v8.1.10
[@speckle/dui3]: [1] [STARTED] Parse Configuration
[@speckle/dui3]: [1] [SUCCESS] Parse Configuration
[@speckle/dui3]: [1] [STARTED] Generate outputs
[@speckle/dui3]: [1] [STARTED] Generate to ./lib/common/generated/gql/
[@speckle/dui3]: [0] [nuxt:tailwindcss] ℹ Using Tailwind CSS from ~/assets/css/tailwind.css
[@speckle/server]: [gqlgen] [SUCCESS] Parse Configuration
[@speckle/server]: [gqlgen] [STARTED] Generate outputs
[@speckle/server]: [gqlgen] [STARTED] Generate to modules/core/graph/generated/graphql.ts
[@speckle/server]: [gqlgen] [STARTED] Generate to modules/cross-server-sync/graph/generated/graphql.ts
[@speckle/server]: [gqlgen] [STARTED] Generate to test/graphql/generated/graphql.ts
[@speckle/server]: [gqlgen] [STARTED] Load GraphQL schemas
[@speckle/preview-service]: [run:watch] INFO: Initializing Prometheus metrics... {"component":"preview-service"}
[@speckle/preview-service]: [run:watch] INFO: 📸 Starting Preview Service background worker {"component":"preview-service/backgroundWorker"}
[@speckle/preview-service]: [run:watch] INFO: Prometheus metrics already initialized {"component":"preview-service"}
[@speckle/preview-service]: [run:watch] INFO: 📡 Started Preview Service server {"component":"preview-service/server"}
[@speckle/preview-service]: [run:watch] INFO: Listening on port 3001 {"component":"preview-service/server"}
[@speckle/preview-service]: [run:watch] INFO: 📊 Started Preview Service metrics server {"component":"preview-service/server"}
[@speckle/preview-service]: [run:watch] INFO: Listening on port 9094 {"component":"preview-service/server"}
[@speckle/preview-service]: [run:watch] ERROR: Error executing task {"component":"preview-service/backgroundWorker"}
[@speckle/preview-service]: [run:watch] err: {
[@speckle/preview-service]: [run:watch] "type": "DatabaseError",
[@speckle/preview-service]: [run:watch] "message": "\n UPDATE object_preview\n SET\n \"previewStatus\" = 1,\n \"lastUpdate\" = NOW()\n FROM (\n SELECT \"streamId\", \"objectId\" FROM object_preview\n WHERE \"previewStatus\" = 0 OR (\"previewStatus\" = 1 AND \"lastUpdate\" < NOW() - INTERVAL '1 WEEK')\n ORDER BY \"priority\" ASC, \"lastUpdate\" ASC\n LIMIT 1\n ) as task\n WHERE object_preview.\"streamId\" = task.\"streamId\" AND object_preview.\"objectId\" = task.\"objectId\"\n RETURNING object_preview.\"streamId\", object_preview.\"objectId\"\n - relation \"object_preview\" does not exist",
[@speckle/preview-service]: [run:watch] "stack":
[@speckle/preview-service]: [run:watch] error:
[@speckle/preview-service]: [run:watch] at Object.raw (/home/ambr/speckle-server/node_modules/knex/lib/knex-builder/make-knex.js:115:30)
[@speckle/preview-service]: [run:watch] at Function.value (/home/ambr/speckle-server/node_modules/knex/lib/knex-builder/make-knex.js:91:29)
[@speckle/preview-service]: [run:watch] at Object.getNextUnstartedObjectPreview (file:///home/ambr/speckle-server/packages/preview-service/dist/src/repositories/objectPreview.js:4:43)
[@speckle/preview-service]: [run:watch] at file:///home/ambr/speckle-server/packages/preview-service/dist/src/services/pollForPreview.js:5:33
[@speckle/preview-service]: [run:watch] at startPreviewService (file:///home/ambr/speckle-server/packages/preview-service/dist/src/server/background.js:52:11)
[@speckle/preview-service]: [run:watch] at async start (file:///home/ambr/speckle-server/packages/preview-service/dist/src/bin.js:6:5)
[@speckle/preview-service]: [run:watch] "length": 113,
[@speckle/preview-service]: [run:watch] "name": "error",
[@speckle/preview-service]: [run:watch] "severity": "ERROR",
[@speckle/preview-service]: [run:watch] "code": "42P01",
[@speckle/preview-service]: [run:watch] "position": "13",
[@speckle/preview-service]: [run:watch] "file": "parse_relation.c",
[@speckle/preview-service]: [run:watch] "line": "1449",
[@speckle/preview-service]: [run:watch] "routine": "parserOpenTable",
[@speckle/preview-service]: [run:watch] "originalStack": "error: \n UPDATE object_preview\n SET\n \"previewStatus\" = 1,\n \"lastUpdate\" = NOW()\n FROM (\n SELECT \"streamId\", \"objectId\" FROM object_preview\n WHERE \"previewStatus\" = 0 OR (\"previewStatus\" = 1 AND \"lastUpdate\" < NOW() - INTERVAL '1 WEEK')\n ORDER BY \"priority\" ASC, \"lastUpdate\" ASC\n LIMIT 1\n ) as task\n WHERE object_preview.\"streamId\" = task.\"streamId\" AND object_preview.\"objectId\" = task.\"objectId\"\n RETURNING object_preview.\"streamId\", object_preview.\"objectId\"\n - relation \"object_preview\" does not exist\n at Parser.parseErrorMessage (/home/ambr/speckle-server/node_modules/pg-protocol/dist/parser.js:287:98)\n at Parser.handlePacket (/home/ambr/speckle-server/node_modules/pg-protocol/dist/parser.js:126:29)\n at Parser.parse (/home/ambr/speckle-server/node_modules/pg-protocol/dist/parser.js:39:38)\n at Socket.<anonymous> (/home/ambr/speckle-server/node_modules/pg-protocol/dist/index.js:11:42)\n at Socket.emit (node:events:517:28)\n at addChunk (node:internal/streams/readable:368:12)\n at readableAddChunk (node:internal/streams/readable:341:9)\n at Readable.push (node:internal/streams/readable:278:10)\n at TCP.onStreamRead (node:internal/stream_base_commons:190:23)"
[@speckle/preview-service]: [run:watch] }
[@speckle/dui3]: [1] [STARTED] Load GraphQL schemas
[@speckle/dui3]: [1] [FAILED]
[@speckle/dui3]: [1] [FAILED] Failed to load schema from 127.0.0.1:3000/graphql:
[@speckle/dui3]: [1] [FAILED] connect ECONNREFUSED 127.0.0.1:3000
[@speckle/dui3]: [1] [FAILED] Error: connect ECONNREFUSED 127.0.0.1:3000
[@speckle/dui3]: [1] [FAILED] at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1555:16)
[@speckle/dui3]: [1] [FAILED] GraphQL Code Generator supports:
[@speckle/dui3]: [1] [FAILED] - ES Modules and CommonJS exports (export as default or named export "schema")
[@speckle/dui3]: [1] [FAILED] - Introspection JSON File
[@speckle/dui3]: [1] [FAILED] - URL of GraphQL endpoint
[@speckle/dui3]: [1] [FAILED] - Multiple files with type definitions (glob expression)
[@speckle/dui3]: [1] [FAILED] - String in config file
[@speckle/dui3]: [1] [FAILED] Try to use one of above options and run codegen again.
[@speckle/dui3]: [1] [SUCCESS] Generate outputs
[@speckle/dui3]: [1] ℹ Watching for changes in /home/ambr/speckle-server/packages/dui3...
[@speckle/frontend-2]: [0] WARN [nuxt] Expected @nuxt/kit to be at least 3.12.2 but got 3.8.2. This might lead to unexpected behavior. Check your package.json or refresh your lockfile.
[@speckle/frontend-2]: [0] WARN [nuxt] Expected @nuxt/schema to be at least 3.12.2 but got 3.8.2. This might lead to unexpected behavior. Check your package.json or refresh your lockfile.
[@speckle/frontend-2]: [1] [STARTED] Parse Configuration
[@speckle/frontend-2]: [1] [SUCCESS] Parse Configuration
[@speckle/frontend-2]: [1] [STARTED] Generate outputs
[@speckle/frontend-2]: [1] [STARTED] Generate to ./lib/common/generated/gql/
[@speckle/frontend-2]: [1] [STARTED] Load GraphQL schemas
[@speckle/frontend-2]: [1] [FAILED]
[@speckle/frontend-2]: [1] [FAILED] Failed to load schema from 127.0.0.1:3000/graphql:
[@speckle/frontend-2]: [1] [FAILED] connect ECONNREFUSED 127.0.0.1:3000
[@speckle/frontend-2]: [1] [FAILED] Error: connect ECONNREFUSED 127.0.0.1:3000
[@speckle/frontend-2]: [1] [FAILED] at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1555:16)
[@speckle/frontend-2]: [1] [FAILED] GraphQL Code Generator supports:
[@speckle/frontend-2]: [1] [FAILED] - ES Modules and CommonJS exports (export as default or named export "schema")
[@speckle/frontend-2]: [1] [FAILED] - Introspection JSON File
[@speckle/frontend-2]: [1] [FAILED] - URL of GraphQL endpoint
[@speckle/frontend-2]: [1] [FAILED] - Multiple files with type definitions (glob expression)
[@speckle/frontend-2]: [1] [FAILED] - String in config file
[@speckle/frontend-2]: [1] [FAILED] Try to use one of above options and run codegen again.
[@speckle/frontend-2]: [1] [SUCCESS] Generate outputs
[@speckle/frontend-2]: [1] ℹ Watching for changes in /home/ambr/speckle-server/packages/frontend-2...
