Speckle Schema Builder Component Grasshopper Structural Elements Missing
Hi David, thanks for your help:
thanks, @AndrewBlackie - that all looks pretty normal. Are you getting the error in the SchemaBuildercomponent not showing all the specklestructural items in this set up? I asked becuase I just reinstalled from the latest installer and am getting SpeckleGH version 1.6.10.741, instead of 1.6.10.0
small update - I installed the latest directly from the SpeckleRhino repo and am seeing version 1.6.10.0. When I install all the components together from speckleworks/SpeckleInstaller I see version 1.6.10.741.
Do you remember what sequence you installed various packages in?
if this problem is in fact related to how the GH component is installed, I’ve made a separate post with info on how to track down the various places components might be hiding: Places you might find a grasshopper plugin
From the version installed in my screengrab I don’t have any issue with the schema builder missing components - this was after downgrading from the most recent Speckle version. I haven’t installed the structural components separately at any point.
Am I correctly interpreting your posts that I should clean out all the locations where the GH components may have been installed and do a fresh install?
Enjoy your weekend - Andrew
Hi Andrew,
Here’s what I suggest:
  1. try re-installing the 1.8.31 clients.
  2. if the SpeckleStructural types do not appear in the Schema Builder Component, open the debugging GH file again and share the output.
  3. if it is showing a bunch of other SpeckleGH plugins isntalled, you can try to remove them and see if it helps!
