Speckle Revit Parameter - Workset
Hi All,
I am trying to push Revit Workset through Grasshopper/Speckle
I am stuck on the ‘units’ input. See attached image. Any idea how I define it for workset ?
Hey @Jia.Y ,
I had to look this up myself! Apparently it’s an optional input (see), does it work without?
Each Parameter will have:
  • a name, either a the Revit display name, BuiltInParameter name or GUID (for shared parameters)
  • a value
  • (optional) Speckle units (mm, cm, m, km, in, ft, yd, mi, none)
