Speackle problem with Kaspersky Total security (firewall)
any chance to get this work without desable the firewall in Kaspersky ? thank you
No need to disable it, if you can tell us what’s the error/problem we can give you some suggestions!
Most likely allowing a few urls or apps might be enough
eatch time
each time I restart speackle it asks me this message, so each time I have to disconnect the firwall to be able to display
using Kaspersky total security 21.3.10.391
Hi @Mayssa_Yasmina ,
Can you try following video below and adding these links to trusted URLs👇:
- *.speckle.xyz (critical)
- *.speckle.dev (critical)
- *.speckle.systems (critical)
- speckle-excel.netlify.app (critical for the Excel connector)
- speckle-releases.ams3.digitaloceanspaces.com
- speckle.community
tryed all links with
https://www.
https://
and without
doesn’t work
Maybe you can try adding manager to the list of trusted apps?
Great it works, thank you
