During the past few days I have been working on a Bill of Quantities report that incorporates data from Revit.
The 3D Viewer sometimes works, other times does not, and gets stuck on the blue bar loading, and after some time an “i” symbol pops up at the bottom with the following message:
Incomplete Data Input
“Stream URL”, “Commit Object ID” and “Object ID” data inputs are mandatory. If your data connector does not output all these columns, please update it.
However when I check the data query, it is populated as expected.
I have tried changing URLs, have used both stream and project URLs, and updated permissions (what worked before was Public Stream, Privacy Level None).
I am using Revit 2023, Revit Connector 2.17, Power BI Desktop, powerbiSpeckleVisual.2.17.0
I’d appreciate your help.
Hi @gokermu, here is the link Viewer - RV5 - Speckle
I noticed that when I open a guest browser, and paste the link, the visual will not load (just the progress bar keeps loading), although public access has been given.
Speckle similarly this link gets suck at about halfway through.
However query data in power bi is populated correctly, so it is not a credentials issue.
thank you in advance!
Unfortunately I can’t make it work.
Did you use the stream/commit version of the link or the project/model, I’m not sure if it makes any difference.
What I noticed is that with the original link I was using, which is this one, Viewer - VIP5 - ISOLATE - Speckle
I can have the visual working for some of the earlier versions, but later versions never load.
In Power BI, I use “Speckle - Get stream by URL (Beta) (Custom)”
Then I select Public Stream, and for “Select which level to apply these settings to” setting I choose the bottom row (same as my link)
You can set it to the top level (app.speckle.systems) so next time when you receive from this server again, you won’t have to authenticate. If you set it same as your model URL, then you will have to authenticate if you were to receive a different model from the same model.
Can you try changing the permission to Server URL from Data Source Settings and see if it solves?
When I add a the last version, it gets stuck in loading, as shown in this video
the same thing happens when I create a new empty file and load only the latest version, or if I try to connect the other model that I sent you originally.
However, I selected fewer elements to push into speckle in a new “lighter” model, and it loaded just fine.
So it feels as if there is something to do with the contents of the model.
Although it’s weird that you were able to visualize the link!
I understand that, however the only reason I tried it is because the link without the @XXXXXXXXX won’t load either! I had the same non-loading issue with the model link Viewer - VIP5 - ISOLATE - Speckle
I do not know what to say @Anastasia. It takes about 10 seconds to load on my end.
Can you create a screenrecording showing what happens when you try to receive this URL: https://app.speckle.systems/projects/011fc423c2/models/cff9d804ff
Thank you for your time and patience! If anyone has a similar issue, try connecting through another network and see if the system persists, and if a company firewall policy is applied, check with your IT Department.
I’ll share my dashboard soon!
