Hi All,
Please may I have your assistance with getting speckle up and running on Azure Kubernetes. The status of the pods are as follows
NAME READY STATUS RESTARTS AGE
pod/speckle-frontend-7945f8648-4tvfb 1/1 Running 0 4d21h
pod/speckle-monitoring-5c59c9c78d-cgmvx 1/1 Running 0 4d21h
pod/speckle-preview-service-85576b6797-vg7w7 1/1 Running 1105 (8m25s ago) 4d21h
pod/speckle-server-7f65d48d55-zh4nj 0/1 CrashLoopBackOff 1128 (5m4s ago) 4d
pod/speckle-webhook-service-6f69bf9fbf-qzl4l 0/1 CrashLoopBackOff 872 (2m20s ago) 4d
When I start a pod in debug mode
PS C:\Users\shiangj> kubectl debug node/aks-agentpool-31857045-vmss000002 -it --image=speckle/speckle-webhook-service:2.12.5-alpha.27056 --env=āREDIS_URL=my_azure_redisu_rl.windows.net:6380,password=my_redis_password,ssl=True,abortConnect=Falseā --env=āPOSTGRES_URL=āpsql host=postgres_host_name.postgres.database.azure.com port=5432 dbname=speckle user=postgres@postgres_host_name password=my_postgres_password sslmode=requireāā
Creating debugging pod node-debugger-aks-agentpool-31857045-vmss000002-m89dq with container debugger on node aks-agentpool-31857045-vmss000002.
If you donāt see a command prompt, try pressing enter.
{ālevelā:āerrorā,ātimeā:ā2023-03-13T16:39:40.160Zā,ācomponentā:āwebhook-serviceā,āerrā:{ātypeā:āErrorā,āmessageā:āconnect ECONNREFUSED 127.0.0.1:5432ā,āstackā:āError: connect ECONNREFUSED 127.0.0.1:5432\n at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1494:16)ā,āerrnoā:-111,ācodeā:āECONNREFUSEDā,āsyscallā:āconnectā,āaddressā:ā127.0.0.1ā,āportā:5432},āmsgā:āError executing taskā}
Error from server (NotFound): pods āhost=pg-ldd-dev-uksouth.postgres.database.azure.comā not found
PS C:\Users\shiangj> kubectl debug node/aks-agentpool-31857045-vmss000002 -it --image=speckle/speckle-server:2.12.5-alpha.27056 --env=āREDIS_URL=speckle-lld.redis.cache.windows.net:6380,password=my_redis_password=,ssl=True,abortConnect=Falseā --env=āPOSTGRES_URL=āpsql host=pg-ldd-dev-uksouth.postgres.database.azure.com port=5432 dbname=speckle user=postgres@pg-ldd-dev-uksouth password=my_postgres_password sslmode=requireāā
Creating debugging pod node-debugger-aks-agentpool-31857045-vmss000002-vfp82 with container debugger on node aks-agentpool-31857045-vmss000002.
{ālevelā:āinfoā,ātimeā:ā2023-03-13T16:51:41.335Zā,āphaseā:ādb-startupā,āmsgā:āLoaded knex conf for productionā}
{ālevelā:āerrorā,ātimeā:ā2023-03-13T16:51:41.818Zā,āerrā:{ātypeā:āErrorā,āmessageā:āconnect ECONNREFUSED 127.0.0.1:5432ā,āstackā:āError: connect ECONNREFUSED 127.0.0.1:5432\n at TCPConnectWrap.afterConnect [as oncomplete] (node:net:1494:16)ā,āerrnoā:-111,ācodeā:āECONNREFUSEDā,āsyscallā:āconnectā,āaddressā:ā127.0.0.1ā,āportā:5432},āmsgā:āconnect ECONNREFUSED 127.0.0.1:5432ā}
{ālevelā:āerrorā,ātimeā:ā2023-03-13T16:51:48.133Zā,ācomponentā:āredisā,āerrā:{ātypeā:āErrorā,āmessageā:āread ECONNRESETā,āstackā:āError: read ECONNRESET\n at TCP.onStreamRead (node:internal/stream_base_commons:217:20)ā,āerrnoā:-104,ācodeā:āECONNRESETā,āsyscallā:āreadā},āmsgā:āRedis encountered an error.ā}
/speckle-server/packages/server/dist/modules/shared/redis/redis.js:18
throw new errors_1.EnvironmentResourceError(āRedis encountered an error.ā, err); //FIXME backoff and retry?
EnvironmentResourceError: Redis encountered an error.: read ECONNRESET
at EventEmitter. (/speckle-server/packages/server/dist/modules/shared/redis/redis.js:18:23)
at EventEmitter.emit (node:events:513:28)
at EventEmitter.emit (node:domain:489:12)
at EventEmitter.silentEmit (/speckle-server/node_modules/ioredis/built/Redis.js:460:30)
at Socket. (/speckle-server/node_modules/ioredis/built/redis/event_handler.js:189:14)
at Object.onceWrapper (node:events:628:26)
at Socket.emit (node:events:525:35)
at Socket.emit (node:domain:489:12)
at emitErrorNT (node:internal/streams/destroy:151:8)
at emitErrorCloseNT (node:internal/streams/destroy:116:3) {
jse_shortmsg: āRedis encountered an error.ā,
jse_cause: Error: read ECONNRESET
at TCP.onStreamRead (node:internal/stream_base_commons:217:20) {
errno: -104,
code: āECONNRESETā,
syscall: āreadā
jse_info: { code: āENVIRONMENT_RESOURCE_ERRORā },
cause: [Function: ve_cause]
Node.js v18.14.1
The strange thing is its trying to connect using local host (127.0.0.1) when Iāve clearly specified the use of the host name. Does this mean my connection string is not the right type for Speckle? Iāve used the same string to connect from a client successfully. Or is it because it cannot resolve the address and by default it will use localhost?
Iām also getting an issue with connecting to Redis (Azure Redis Cache), my feeling is these are related.
Any help would be greatly appreciated
Kind Regards
John
