Speckle not receiving models from Rhino (although says receive complete)
Speckle: version 2.20.4, downgraded to 2.20.3 as well to test but same outcome.
Objective: import Rhino geometry into Revit.
Issue: Models to do load in, despite following all workflow as have done previously and it working.
happy to upload logs but doesn’t seem to allow me.
As mentioned, I have done this before and its worked totally fine. It doesn’t matter what version, my visibility settings (I tested in a brand new Revit file, to no avail), the scale (I opened in web browser to view, it was there and was nearly 6m in length, shouldn’t be an issue)… now I am perplexed!
Thanks for anyone’s help :slight_smile:
Can you please share with us:
  • the Speckle project with your data
  • the original Rhino file
I have just shared a Drive folder to your email, you can use that and upload your logs too.
Also, please have a go with our next-gen connectors (v3), currently in beta: Introducing Next-Gen Connectors
Speckle project: https://app.speckle.systems/projects/549b3ec013/models/1dc28bfd9f
I am awaiting permission to access the folder to upload the rhino model. Kind regards
I have given access to both your personal and work emails, let us know when the files are up!
Done! thank you. let me know when you received it :slight_smile:
Hi @leoali,
Thanks for sending the files!
I have a question: where did this model come from? Was it created in Rhino or another software?
Did you receive this model in Rhino from another app using Speckle?
From a quick look, the geometry seems fine, but when converted to a mesh, it ends up with over 1 million vertices. It would be helpful to know how this geometry was originally created.
Thank you!
