i have tried the workflow from rhino to revit with the speckle mapper.
i integrated levels and families in rhino with speckle and mapped everything according to my needs.
when transfering the elements into revit, everything is kind of shifted and not on the correct position anymore. have you every faced errors llike this?
It worked for walls and floors, but structural columns and beams show up in different heights.
If the columns and beams are at the right elevation, make sure that the level associated with them is correct too, for this you might need to select “Revit Beam” and “Revit Column” as target type.
If this fails too then it might be a bug which I can report to the team.
