Hey guys,
I have a weird problem. I don’t have speckle connector installed but when I open Speckle Manager I see an update for it. Even if I select uninstall, update is still visible.
I think this might be a bug or something.
Hey guys,
Can you check under “Apps and Features” if it shows there?
Alternatively, it could be a registry key that didn’t get correctly deleted. To remove it, you could
C1A57482-4D24-4C38-A788-28518613DB4B
and delete themhey @teocomi,
i checked and its not installed.
interestingly, after i installed blender connector, i got an update for speckle manager. i dont know if its just a coincidence or not. i installed it anyway.
now, i cant delete the connector.
What happens if you go in the Settings and click “Reset Manager”?
still shows as if blender’s connecter is installed.
So there was a key in the registry left from an older version of the installer, we had to manually delete it.
Yep, that was it. thanks @teocomi
