We are facing an issue when trying to connect from speckle manager to our Speckle Server (2.18.5-alpha.81844). From the web application we are having no troubles.
We get the following error when trying to authorize the request from the speckle server.
On the manager logs we see the following error being displayed.
2024-03-27 14:06:23.510 +00:00 [INF] Execution of http request to
https://xyz.com//graphql
succeeded with “BadRequest” after 0.0909924 seconds and 0 retries
2024-03-27 14:06:23.607 +00:00 [FTL] Failed to add account: Failed to create account from access code and challenge
Speckle.Core.Credentials.SpeckleAccountManagerException: Failed to create account from access code and challenge
—> Speckle.Core.Logging.SpeckleException: Failed to get user + server info from
https://xyz.com/
—> Speckle.Core.Api.SpeckleGraphQLException`1[Speckle.Core.Credentials.ActiveUserServerInfoResponse]: Query GetUserServerInfo failed
at Speckle.Core.Credentials.AccountManager.GetUserServerInfo(String token, Uri server, CancellationToken ct)
— End of inner exception stack trace —
at Speckle.Core.Credentials.AccountManager.CreateAccount(String accessCode, String challenge, String server)
at Speckle.Core.Credentials.AccountManager.AddAccount(String server)
It would be great if you could help us with any directions to resolve the same.
