History is a great idea,
are already in place any best practices to track the history of the streams?
It seems that with Dynamo if I copy-paste the stream it won’t work.
In Rhino I can add an element to the stream and it will display in the history tab
It’s a good shout. Here’s how it works right now:
- Dynamo and Grasshopper: they create stream history instances only in “manual mode”
- Rhino, Revit: on every push.
We’re still working through the best models to expose this, so if any opinions on the matter do shoot!
Thanks Dimitrie,
in Dynamo Grasshopper even if I change the object the history of the stream will stay the same as the streamID. what should I do to see and track the history?!
I am in the “manual mode”.
If you are in manual mode, then every time you “push”, this will create a child streams. You can see the “snapshots” in the admin (for example: Speckle) or as well by right clicking a receiver, and going under “children”.
To access that specific snapshot, you just need to create a receiver with the snapshot’s streamId
, and voila.
As I said, we’re aware this is not an ideal workflow. We’re working on improving this, and there’s some ideas floating around to shape this:
- all sender clients create “history”.
- users can tag snapshots with whatever they want, ie “v.0.0.1”, “STAGE_XXX-deliverable”, etc.
- receivers, by default, will receive the latest “tag”, but you’ll be able through the ui select which “tag” you want to receive (so we remove some of the hassle of creating a new receiver).
The above is just an idea, input is welcome.
Oh, thank you so much, Dimitrie.
I found your ideas pretty useful:
- Definitely, it would be awesome for the receivers to select the tag that they want to receive.
I presume also this could be well integrated with the work @pauldotnet is doing with the graph, the receiver can select the flow with a UI in the graph. https://twitter.com/paul_dotnet/status/1153372073793859585?s=20
