I installed the Speckle Connector for Autocad but it is not visible inside AutoCAD 2023 even if I type “speckle” in the command line, just a “Unknown command” message. I tried to reinstall the connector and restart AutoCAD but it did not help. Right now I run AutoCAD as trial license. Any idea how to find out what is wrong?
Hi @MaxT , currently we’re only supporting AutoCAD 2021 & 2022! We can add 2023 support in the upcoming sprints
Thanks a lot, no hurry, I have lots of other Connectors to play with.
You were fast @MaxT , I believe acad 2023 was just released 2 days ago!
Just my luck, it was the only trial version I could find. I should have downloaded it last week.
Hi there,
Is it not possible to get Speckle - Autocad for older versions? (from 2018).
Thank you!
Hello @oda_federico ,
Unfortunately, we’re a small team and are not able to support such old versions, but good news: Speckle is open source and this means that you can probably find a developer to make our code work for earlier versions too.
