Hello, I am trying to access a stream and download its members to use the on a standalone WPF app. I wrote a method to receive these members and cast them into the desired objects. Please find the code below. Even though it receives the stream just fine on a number of machines, I am not able to receive the members and the Operations.Receive method doesn’t seem to resolve. Would you have any idea what the issue may be? Thank you in advance.
Code:
/// <summary>
/// Receives the data from an account and one of its streams
/// </summary>
private async Task ReceiveData(Stream stream, Account account)
if (streamAnnotations != null) streamAnnotations.Clear();
List<Branch> branches = await client.StreamGetBranches(stream.id, 10, 10);
var transport = new ServerTransport(account, stream.id);
var @base = await Operations.Receive(branches[0].commits.items[0].referencedObject, remoteTransport: transport);
var receivedBaseObjects = ((IEnumerable)@base.GetMembers()["objects"]).Cast<Base>().ToList();
streamAnnotations = receivedBaseObjects.Select(x => ConvertBaseToAnnotation((Base)x)).ToList();
UpdateUI(streamAnnotations);
Ah, and I’ll follow up with a brainwave: if basically just things hang on the Operations.Receive call without returning, it might be because of mess-ified threading context and other crazy .net stuff. To see if this is the actual culprit, can you try to do
var @base = Operations.Receive(branches[0].commits.items[0].referencedObject, remoteTransport: transport).Result;
Hello @dimitrie and thank you for welcoming me to the community. To give a bit more context, I am building a WPF application, with the intent of it being integrated into Revit. The aim of it is to receive some metadata related to the stream’s objects and display them as a list on the window. We have run the same solution on a number of machines and it receives the data just fine, while on the machine I need to work on it doesn’t, despite being the exact same solution. I also run tests with other web requests and disabled the firewall to test if the firewall was blocking it, but the issue still persists.
I also added the above line, but still the program doesn’t execute any statements after that line.
Okay, it’s then a spooky bug. Does the machine you need it to work on have a valid account that has access to the stream you’re picking data from in there? I suspect you checked this…
We could jump on a quick call if you want to try and debug things live - is there a way we can look at that specific windows machine?
Even if you don’t use .Result in your code, Operations.Receive will use it internally anyway in some places. So it’s best not to call the receiving methods on the UI thread.
The easiest way to handle this, is to force the async data-loading methods on a worker thread (not the UI thread), by wrapping the async method call with Task.Run. For example, instead of
With this approach, you should also make sure you update the UI from the UI thread, and not from the background thread that made the request. (google has plenty of resources around this)
Thank you Cristian, I will try running the reception on a different thread and I well let you know how it works. Thanks again for your time and effort.
