We`ve a problem when a user of my organization try to import the model from speckle to Power BI using the Speckle connector. He is owner as me. It happens to him with one project and not with another one. Permissions are exactly the same in both of them. Do you know why? I attach a screenshot. Thank you very much.
teocomi
(Matteo Cominetti)
9 December 2024 10:23
2
Hi @Maite_Aguirre_Valles can you please confirm the Project is set to Link Shareable ?
It´s discoverable, as the other project.
gokermu
(Mucahit Bilal GOKER)
10 December 2024 10:01
5
Hey @Maite_Aguirre_Valles ,
Can you check the following solutions and let us know if any of them helped?
It seems to be a PowerBI issue due to how it stores (and sometimes loses) credentials.
The guidance I have found is to clear permissions for the Speckle data source you are using (perhaps app. sickle.systems) and re-authenticate.
Open Power BI Desktop, when you already created visuals use the existing pbix
go to File → Options and settings → Data source settings
Check “Data sources in current file” and “Global permissions”, mark any source that points to the new Speckle server and hit “Clea…
If above doesn’t work, can you try authenticating with a Personal Access Token and try again?
system
(system)
Closed
8 June 2025 10:01
6
