Speckle 3.0.0-beta.215 - Network Error
Today I am reaching out regarding the Speckle 3.0.0-beta.215. I have a trouble with connection to the server. It concerns Revit and Rhino connector. Any idea how to fix that ? ( I am sure that I have an internet connection)
Speckle v2 is working normally in both software
Hi @mwoch
which Speckle server are you attempting to use? app.speckle.systems? or some other server?
global server - app.speckle.system :slight_smile:
Hi @mwoch,
We are on it now!
To be able to narrow down the issue that you are having, is there any account on your manager address any local server or other servers.
Best
Unfortunately not. I am using only a global server right now. No local aliases
I’ve pushed a fix by guessing, could you try again?
PS: you do not need to re-install anything.
Network connection is working, however now I’ve noticed the conversion issue in v3 connector
When I load the same model from the same project, but using v2, it’s working normally
Happy to hear your network issue is resolved.
We do not promise v2 models will work in v3, because we have changed our object model quite a lot. You could try to send it from v3 connectors.
Best
Oh, I see. I will try Send/Receive using only v3. Thanks for your advice and help with network bug. I think we can close the thread :slight_smile:
Thanks to you too reporting it!
