I am trying to open up speckle within Revit but keep getting the error attached in the screenshot.
I am using version 2.14.0, I have to se the older version for transferring Pipe networks from Civil 3D to Revit. is thee anything i could do to help this, i have already tried to remove and redownload the connectors.
I have attempted to go back to 2.14.0 again and I am able to access speckle again but am still getting the error that is above and cant see any of my projects
Could you describe a bit more why you need to stay on 2.14? Have you tried the latest 2.21 versions?
The error in the screenshot seems to suggest not all files were 2.14.4.
I’d recommend you ensure all your Speckle connectors uninstalled, then installed again on the same version to avoid any conflicts.
The reason i am on 2.14.0 is that when transferring pipe networks from civil 3d to Revit in the newest version it just changed them to a generic model meanwhile my coworker who is using 2.14.0 is keeps them as a pipe with the properties of a pipe. to my knowledge this was the only difference between us. my speckle for civil 3d did get updated with out my knowledge, i will try to revert this and attempt again.
When rolling back my Civil 3D connector it failed to convert the pipe network. Is there a way to transfer a pipe network from Civil 3D to Revit whilst keeping the properties of pipe with the newest versions of the Speckle connectors?
