Hi everyone,
why does the Speckle 2 Receive node causes my Dynamo to crash?
Here are the steps I took that lead to the crash:
- Create a script with the Speckle 2 Receive Node in it.
- Run script and successfully received data from server.
- Close script and Dynamo (sometimes I do not close Dynamo) save.
- Open Dynamo and run script again.
- Error appears on the Receive node and if I close the script or delete said node Dynamo crashes.
Here is the crash report:
One or more errors occurred.
at System.Threading.Tasks.Task`1.GetResultCore(Boolean waitCompletionNotification)
at Speckle.ConnectorDynamo.ReceiveNode.Receive.get_Client() in C:\Users\circleci\project\ConnectorDynamo\ConnectorDynamo\ReceiveNode\Receive.cs:line 51
at Speckle.ConnectorDynamo.ReceiveNode.Receive.Dispose() in C:\Users\circleci\project\ConnectorDynamo\ConnectorDynamo\ReceiveNode\Receive.cs:line 605
at Dynamo.Graph.Workspaces.WorkspaceModel.Clear()
at Dynamo.Graph.Workspaces.HomeWorkspaceModel.Clear()
at Dynamo.Models.DynamoModel.ClearCurrentWorkspace()
at Dynamo.ViewModels.DynamoViewModel.ClearHomeWorkspaceInternal()
at Dynamo.ViewModels.DynamoViewModel.CloseHomeWorkspace(Object parameter)
at MS.Internal.Commands.CommandHelpers.CriticalExecuteCommandSource(ICommandSource commandSource, Boolean userInitiated)
at System.Windows.Controls.Primitives.ButtonBase.OnClick()
at System.Windows.Controls.Button.OnClick()
at System.Windows.Controls.Primitives.ButtonBase.OnMouseLeftButtonUp(MouseButtonEventArgs e)
at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
at System.Windows.RoutedEventHandlerInfo.InvokeHandler(Object target, RoutedEventArgs routedEventArgs)
at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
at System.Windows.UIElement.ReRaiseEventAs(DependencyObject sender, RoutedEventArgs args, RoutedEvent newEvent)
at System.Windows.UIElement.OnMouseUpThunk(Object sender, MouseButtonEventArgs e)
at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
at System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
at System.Windows.Input.InputManager.ProcessStagingArea()
at System.Windows.Input.InputManager.ProcessInput(InputEventArgs input)
at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
