So long Revit 2019
Hello Specklers,
This is an announcement that we have officially dropped support for Revit 2019. We’ve made a change to the Speckle revit connector that doesn’t work for version 2019, and there are not enough users still using version 2019 in order to justify fixing this version.
If you would like to continue to use the Speckle connector in revit 2019, you can download the last working version of the connector at the following link.
https://releases.speckle.dev/installers/revit/Speckle%20for%20Revit%202019%20v2.8.3.exe
