Snapping to Direct Shapes in Revit
I’m testing the workflow from skp to rvt. This may be more of a question for a Revit forum but I’ll start here.
When I receive direct shapes from skp I cannot use the geometry to snap to. Pick lines or even snapping to endpoints doesn’t work.
Is this possible or are there limitations to Revit and how it sees/uses direct shapes.
Scott
Further to this query I noticed when I passed the geometry not in a group it added lines on the edges, lines(curves) as you’ll notice pass through no trouble.
Hey @scottyvalentine ,
Indeed this is a Revit limitation. As you know, Sketchup is a mesh-based application. In Revit, Direct Shapes meshes do not support snapping. We have some ideas to get around this limitation but this may take a couple of releases. Our current priority is adding more mapping methods (creating floors from faces etc.).
BTW, have you seen the mapping tool for Sketchup?
Hi Mucahit,
Thanks for that response. I suspected it was revit limited direct shape behaviour. I will assume if it’s a direct shape brep then there’s no issues. But SketchUp and Blender don’t model in surfaces so I’m out of luck for now.
The mapping worked really well. I don’t use SketchUp, I highly dislike it, but I was forced to on a small project recently. To ensure the model can be worked with I manually setup groups like categories in Revit. The good thing about the mapper is I can just select the group and make it walls, or whatever. Giving me full control over how the model appears in Revit. Now if I could only use snap and pick lines then I’d have a great workflow to take crappé SketchUp to amazing revit.
